1.5mm vs 2.5mm mains |
Post Reply | Page 12> |
Grubbah
Old Croc Joined: 14 July 2011 Location: Portsmouth Status: Offline Points: 2004 |
Posted: 21 June 2016 at 9:40am |
I'm making up a load of in and out adaptors for a bunch of Martin moving heads in my lighting rig.
Simply a male 16a to a female 16a and back out to another female. The idea being I can run all 8 off a single 16a feed, making the rig tidy. The tails will be 1M either side My head said I should make these out of 2.5mm H07-RNF, my wallet wants to make it with 1.5mm as I can get a drum with over twice as much cable for the same price. Would 1.5mm be ok use?
imageoven
Old Croc Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2186 |
You might struggle to get 2 x 2.5mm2 into a 16A plug/ socket contacts / strain relief and its generaly not approved of because of this (although common).
http://cpc.farnell.com/lewden/pm16-a131g/splitter-16a-240v-splitline-black/dp/PL10886 These make a lot more sense although you may need short 16A - 16As too Lewden are ok quality, similar things can be had for under £9. |
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4575 |
Go 2.5 H07.
If it doesn't fit, you shouldn't be doing it ;) (ie the splitter cables) For what you want, use 16a T lines. http://m.stage-electrics.co.uk/shop/sales/connectors/power/230volt-single-phase/16a-blue-single-phase/product.aspx?code=636-3592 Edited by dylan-penguinmedia - 21 June 2016 at 1:26pm |
AM55
Old Croc Joined: 16 August 2007 Location: Matlock Status: Offline Points: 1728 |
dylan-penguinmedia
Oh and a home made in / out 16a doesn't maintain the IP rating
MattStolton
1.5mm is basically for heavy duty BS1363 13A socket ness.
Anything 16A BS4343 plugs (Cee form) requires 2.5mm, really. It will be fused at 16A, probably on a C curve to boot, so 1.5mm wont pass mustard! However, the IEC60309 spec for Cee Forms also specifies maximum cable gauge, and 16A cee is rated to take up to 5mm2, i.e. two 2.5mm2. Try bootlace ferules. I picked up a hex crimp tool (nicer than the square ones), with container of ferules, 0.5 to 6mm, for about £25 from ebay. Makes life so much more pleasant. Also, when you have to pass one end through a wall (make sure you pass the end that goes towards the upstream fuse, guarantees no voltage on the bare wires!!!) the ferules mean you don't have to cut back and re-terminate, so your leads last longer, and stay longer!!
norty303
Agreed on the T-Lines although I prefer to use the ceeforms and t-lines from the black range from PCE
https://www.essentialsupplies.co.uk/cgi-bin/sh000071.cgi?WD=black%20pce&PN=T%2dConnector%2dAll%2dBlack%2dmade%2dby%2dPCE%2dEAD16B%2ehtml#SID=47 |
toastyghost
Us too, way better quality. |
Andylaser
Registered User Joined: 16 April 2010 Location: Southampton Status: Offline Points: 300 |
Much easier to work on as well.
KES are a good source for PCE connectors. Edited by Andylaser - 25 June 2016 at 5:38pm |
"music so loud, that if we move in next door to you; your lawn will die" - Lemmy
amlu
Young Croc Joined: 30 November 2009 Location: london Status: Offline Points: 740 |
You will struggle a lot with getting 2x 2.5 cable into a 16a plug/socket. Little better with 1.5 but it will still look rough.
+1 on 16a splitters mentioned above... |
haymere
Young Croc Joined: 28 December 2007 Location: Liverpuddle Status: Offline Points: 585 |
Go 1.5mm as you can do circuits of up to 22m before you have voltage drop
haymere
P.S. I have done a voltage drop spreadsheet which it would be useful to pin for everyone, mods can you help me get it across
