1 x 10" |
Page 12> |
| Author | ||
Tekasis
Topic: 1 x 10"Posted: 10 May 2011 at 11:22pm |
ok mate, remember to keep the pics coming on the new ones.
**Heavy Weight-Line**
A home without books is like a body with no soul. |
colint
Joined: 06 October 2007 Location: United Kingdom Status: Online Points: 3303 |
Posted: 09 May 2011 at 9:17pm |
It's not moved on that much to be honest, the cabs are still not painted but the boys have had them loaded, the comp ended up to be a de16 B & C and they did try some Thormann "the box" 10" drivers which didn't sound bad for the 38 quid each that they cost but the power handling was quite low at 250 watts each.
The boys used these nye (with the mth 30's) with great effect and got comment's on how good it sounded, venue was a wine bar with about 200 punters
I'm going to start on these again when they have the cash to buy the P-audio SN2-10mb bass drivers to go in the cabs which are neo and 600 watts each. These are going to still be used with the MTH30's as it seems a nice sounding portable system (especially for a starter system) and as they won't be getting used to much will stay in MDF, I do intend to build another pair for myself but those will be in birch and loaded with the same drivers (assuming I ever get my finances sorted) But they are a nice sounding loud cab! Edited by colint - 09 May 2011 at 9:48pm |
No matter what you put into your system if your speakers are shite it'll sound shite! Simple init?
Tekasis
Posted: 09 May 2011 at 7:02pm |
Colint, whatever happened with the results of this build ? Was looking interesting.
Edited by Tekasis - 09 May 2011 at 7:03pm |
colint
Posted: 31 July 2010 at 6:48pm |
I was looking at the de16 but they have gone now so considering looking at the BMS drivers instead.
I did think of the 18 sound comp's but they are so expensive and quite had to get hold of for some reason (mind you I'm not having much luck with the 10md600 at the moment either?)
Glenn
Joined: 01 October 2008 Location: Australia Status: Offline Points: 186 |
Posted: 31 July 2010 at 6:13pm |
Let us know how this ends up sounding. The 10mb600 would be in the shortlist if I had to do a 10" mid bass.
Obvious choice for comp would be DE250 or one of the celestion offerings are said to be just as good these days.
colint
Posted: 30 July 2010 at 8:32pm |
Found a nice plan that I already had on the hard drive (what a muppet) so box build is now on the way for a 1 x 10" full range/mid high loaded with a 18 sound 10MB600 bass drive and a B & C comp (haven't decided which one yet) on an 18 sound XT120 1" horn!
Rated at 600watts it should be a nice sounding cab in a small package! This is going to used on top of an MTH 30 for smaller gig's and a pair of 2 x 15" reflex cab's for the larger stuff! Edit for pic! Mdf construction which will be re-built in birch once the cab is finalised & tuned! ![]() Edited by colint - 30 July 2010 at 8:43pm |
colint
Posted: 30 June 2010 at 11:07pm |
Thanks for the heads up but I've seen that one, the reason I'm looking for a ready made plan is I want my son-in-law to build it with a little help from myself so I don't want anything to complicated but it has to sound good to give him a leg up so to speak! Lol
Griffin
Joined: 11 August 2009 Location: Cornwall Status: Online Points: 49 |
Posted: 30 June 2010 at 6:32pm |
There is one on the Fane website.
_djk_
Joined: 23 November 2004 Location: United States Status: Offline Points: 3516 |
Posted: 27 June 2010 at 4:21am |
http://www.speakerstore.nl/constructions/2
http://www.speakerstore.nl/constructions/18sfr101/FR101MK2.pdf Edited by _djk_ - 27 June 2010 at 4:26am |
djk
djeddie
Joined: 26 April 2004 Location: Bristol Status: Offline Points: 1739 |
Posted: 26 June 2010 at 10:48pm |
Then why not re-do the plans with a trap shape?
E=mc² ±3dB
colint
Posted: 26 June 2010 at 10:27pm |
Thanks for the heads up but I've already seen those! What i want is a 1 x 10" trap cab!
djyves
Joined: 06 April 2009 Location: the Netherlands Status: Offline Points: 486 |
Posted: 26 June 2010 at 10:13pm |
"If brute force doesn't work, you're not using enough!"
Page 12> |
Tweet
