Forum Home Forum Home > Buying and Selling > Wanted
  New Posts New Posts RSS Feed - 10/12u Foam mount flight case
boots-hifi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boots-hifi Quote  Post ReplyReply Direct Link To This Post Topic: 10/12u Foam mount flight case
    Posted: 25 September 2016 at 8:06pm
Looking for ideally 12u but 10u will do, foam lined flight case. Needs to be deep enough for MC2 MC series so not massively deep. Im located near Watford, I can collect with in reason. Cheers.
DPR2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DPR2001 Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2016 at 11:31am
Hi,
I have a number of 10u foam suspended flightcases, 500mm depth on centre box, front and back rail and doors:
150 (sf discount) and can meet you in Oxford on a weekend for £20.
deja-ibiza View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote deja-ibiza Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2016 at 2:41pm
I've got a 12u foam lined Flightcase available. It's MC2 depth, on castors, Diamond-board. Located near J10, M25.
Pics and & measurements can follow later today.
Edited by deja-ibiza - 26 September 2016 at 2:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote deja-ibiza Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2016 at 5:36pm
Pics of the case I have below.
It has front and rear rack strip, as well as an inner rack strip towards the rear (see last pic)
Measurements are:
570mm front to rear rack strip
470mm front to rear inner rack strip.
75mm lid depth
(Please ignore the patch panel)
Edited by deja-ibiza - 26 September 2016 at 5:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote boots-hifi Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2016 at 6:32pm
Thanks, can you pm the price for the 12u please.
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2016 at 8:02pm
I have loads of flashlight 12u steel framed rack cases.
Check eBay they are on there. Will do better prices for SP members.
Probably your only chance to get multiple matching cases without buying new.
J
midas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote midas Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2016 at 9:14pm
Flightcase wearhouse, 12u new with casters 199.00
Studiospares 8u foam, new 129.00. Must have sold 12u but not much more when they are in stock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote boots-hifi Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2016 at 9:52pm
Cheers, ill have a look!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2016 at 7:50am
Cheep foam ones are normally shite, as they are just lined with cheap foam and eventuallly where the sleeve sits on the foam it will compact it.
More expensive foam cases like the looks of the one DJ-Ibiza posted will have rubber pads in the middle of the foam to take the weight of the sleeve when upright.
J
supremesoundz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote supremesoundz Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2016 at 10:40am
18u and a 10u. Very very good cases
Post Options Post Options   Thanks (0) Thanks(0)   Quote supremesoundz Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2016 at 10:46am
18u £120
10u £100
Cases by AOS London in diamond board finish
Based in the Uxbridge area. Although the 18u case is in Heston (you've been there before Ben)
Post Options Post Options   Thanks (0) Thanks(0)   Quote boots-hifi Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2016 at 8:57pm
Pm'd. You love those FBT's !
