  New Posts New Posts RSS Feed - 10,000 watt macro tech
samson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote samson Quote  Post ReplyReply Direct Link To This Post Topic: 10,000 watt macro tech
    Posted: 27 October 2009 at 12:20am
Hi guys came accros this picture of a 10,000watt macro tech amp..
Is this a picture of a prototype? Or maybe a failed attemp by crown to build such a beast?
Must weigh a ton if a prototype does existShocked
Wisdom is better then silver and gold..
cilla.scope View Drop Down
Legs all the way to her bottom....
Post Options Post Options   Thanks (0) Thanks(0)   Quote cilla.scope Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2009 at 12:53am
http://www.crownaudio.com/pdf/legacy/k10684.pdf
seems it was intended for stadium use ... down into 0.5R   .. but otherwise, not particularly powerfu.. especially when you consider the 10,000 watts was only for a single cycle of 1khz .. was down to 6K for a 40ms burst .. RMS was probaly 3K  or so ...
I think I saw one of these driving a vibration test rig once ...
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2009 at 1:21am
they were a full production item but presumably not many were sold, remember Crown, Amcron and AE Techron are the same company but AE T. specialise in medical equipment ie MRI scanner coil drivers- that's probably the genesis of this unit. Output current capability more impressive than voltage so works best on v. low impedance loads.
8x PD1850's hanging off this thing would be saying plenty i reckon!
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2009 at 1:37am
It's impressively large but the Crest 10001 is more impressive in terms of power output.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2009 at 1:44am
The Crown Macro-Tech 10,000 requires 3-Phase 208 volts in order to operate. Who is moving about with that type of voltage.
It is the main reason why it never caught on in the States. There is a shop in New York that has one for display purposes.
Best Regards,
colint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote colint Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2009 at 5:15am
So would your back tryiny to move it? I saw one of these at one of the plasa shows on the shuttlesound stand (display only)
it was huge, they said one was installed at of of the usa motor race tracks powering 64 bose 802's?
DjMidKnight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DjMidKnight Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2009 at 5:46am
Best Regards,
Actually any venue large enough to need that kind of sound would have 208 3phase. 3phase is fairly standard in commercial buildings. given its not a standard but most major venues should have it.  none the less an amp of that magnatude isnt intended for the average end user there built for installation.
Wikl109 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wikl109 Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2009 at 9:50am
I love stuff like this. Way over the top equipment that manufacturers simply wouldn't make now due to the cost issues. Some of the high end 'home' speaker systems Tannoy and JBL used to make were also just stupid.
Just look at some of the specs of this Crown monster, 80 output devices, gulp!
burningbush View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote burningbush Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2009 at 10:48am
Looks like it should have its own gravity field.
numtie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote numtie Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2009 at 1:19pm
wasnt it crown who also produced the infamous 1u belchfire LOL
Disco Hire Wales
CLsystems View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CLsystems Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2009 at 2:15pm
i believe it was indianapolis speedway, that had these.
jonminns View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonminns Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2009 at 2:16pm
The belchfire was a comedy datasheet production by crown, really quite funny for nerds such as myself
The MA10,000 is intended for running to very low impedance loads (eg a large impedance based paging system rather than 100v)
4 ohms is for wimps
