  New Posts New Posts RSS Feed - 10"bass binns
10"bass binns
BERTIE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BERTIE Quote  Post ReplyReply Direct Link To This Post Topic: 10"bass binns
    Posted: 12 January 2007 at 5:25pm
This is my first post on SPEAKERPLANS,allthough i'm visiting this exellent site for more than a year !! I recently performed on a PA system in South Africa that uses 10" bass binns.The system covered 5 000 people in a huge tent.For this capacity obviously the bass was not at all up to standard,but, could be very usefull for much smaller venues.Unfortunately i did not had the time to take a closer look at the system.I've been looking all over the place for 10" bass binns, 1 x 10 or 2 x 10, but cannot find anything.Is there perhaps one of you gents that can guide me to something usefull
WHERE THERE'S A WILL,THERE'S A WAY !!!
Disco Stu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Disco Stu Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2007 at 7:52am
www.billfitzmaurice.com
Tuba 24 or Titan 39. Uses Eminence HL10 drivers or Beta 10s under low power, other similar drivers work but the HL10 is king for 10" horn subs
All you need to know is:
My acts:
Post Options Post Options   Thanks (0) Thanks(0)   Quote BERTIE Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2007 at 6:26pm
Thank you very much I have 8 Delta 10's that came out of my old system(mids) that I can put to better use.I'll let you know what they're up to once I've ordered the plans and build two.
This page was generated in 0.202 seconds.
