10inch scoop? |
Post Reply | Page <123> |
(SoundcreationaudiO)
Registered User Joined: 09 October 2007 Location: Wales Status: Offline Points: 306 |
yeh, theres those who will say that it fundimentaly wont work, but i built one, and it shock the sh*t out my flat! not the most perfectly balanced, note perfect cab, bit peaky... but it worked.. very good at 35hz-60hz,, few peaks and troughs throughout, before and after.. you want to ask nineleaves on here to design you one specifically for say the peerless.. the guys a genius..;)
Autograff
Young Croc Joined: 22 October 2008 Location: Sheffield , UK. Status: Offline Points: 1361 |
Why not build a punisher?12" and a seriously good box.
buffsterkris
Registered User Joined: 28 May 2008 Location: norwich Status: Offline Points: 22 |
becuase i want a mini scoop. or i wud have built something else..its only for in my bedroom neway. maybe the livin room hooked up to the cd player i dno. and as for soundcreation thanks man ive bin gettin ridiculus amounts of sh*t off ppl sayin it wont work, wud thismy man charge me for a design then or what?
starting to make a system...ne help appreciated
Autograff
15" Mini-Hog maybe?
buffsterkris
NO!!!! no 15inch that or 12inch this. it is going to b a 10 inch scoop. possibly the hog design that i was told about if not i will fin plenty of other types of scoop to try,
cravings
ok in the other thread you weren't told ( you certainly weren't "fukin slated"... you just didn't show any signs of listening...) that it flat wouldn't work, you were told that there's more to it than just scaling down a cab. you still need to use an appropriate driver for the box. that is the key thing.
mykey
it would work but you would have to start from scratch, just scaling down isn't going to work as good as a fresh design
if you want it to go low it will still have to be a longhorn
get scaling down out of your mind
Autograff
just suggesting was all..
mykey
sorry autograph, wasn't having a go at anyone
[QUOTE=mykey]it would work but you would have to start from scratch, just scaling down isn't going to work as good as a fresh design
spot on....
italgil
Registered User Joined: 21 September 2011 Location: Portugal Status: Offline Points: 21 |
Can you name some suitable drivers?
MarjanM
Why not a micro 21 scoop? :-)
