115V crest 10004 to 230V country |
AndyWave
Joined: 30 March 2008 Location: Finland Status: Offline Points: 203 |
Topic: 115V crest 10004 to 230V countryPosted: 12 February 2012 at 1:18pm |
Does the crest 10004 amplifier have dual windings in transformer primary, so that I can change operation voltage from 115V to 230V?
I've sent an e-mail two times to crest support but got no reply. Also got no reply from finnish authorized crest service. Crest documentation refers that the operation voltage is "factory configured", whatever that means... |
torturing electrons since ......
TRE4U2NV
Joined: 21 May 2005 Location: home Status: Offline Points: 1960 |
Posted: 12 February 2012 at 10:57pm |
speak to bruce at ampman audio or jon the boss
Paulo Duto
Joined: 06 January 2005 Location: Brazil Status: Offline Points: 116 |
Posted: 12 February 2012 at 11:15pm |
Hi!
http://www.crestaudio.com/schematics/ Regards, |
Paulo Duto
AndyWave
Posted: 13 February 2012 at 7:55am |
Than you all for your replys. I'm sorry announce that crest 10004 schematic set does not contain the connection diagram for the transformer primaries nor the circuitbreaker.
Anyone of you actually made the change? |
haloweenhamster
Joined: 24 January 2010 Location: Birmingham Status: Offline Points: 515 |
Posted: 13 February 2012 at 1:08pm |
Normally there are 2 primaries run in series or parallel
Try & find an owner to take lid off & look @ torroid ie label/number of cables |
2x court top horn 2" + 1" loaded
2x court mid horn 12" loaded 2x ass mt1200 10" + 2" + bullets 2x court W bins 15" loaded 1x/3x TAS sub 18" loaded |
djkeet
Joined: 26 December 2011 Location: England Status: Offline Points: 52 |
Posted: 15 February 2012 at 10:53pm |
Try these people
http://www.bigbluerig.co.uk/index2.html |
Soundbite
Soundboy20
Joined: 09 October 2006 Status: Offline Points: 412 |
Posted: 17 February 2012 at 3:28pm |
I wondered how long it would be before my name got mentioned - haha! Both myself & Bruce have been asked this question a lot in the last year odd! The easiest way is if you can get the serial numbers of the amps your looking at. Cheers Rex |
RCH Audio Engineering
haloweenhamster
Posted: 21 February 2012 at 2:51pm |
Opened my one last night to find my one had been converted, can see where grey cable has been cut off power switch & connected to a white cable but I was working on the back so didn't look to see what else has been changed
Soundboy20
Posted: 21 February 2012 at 10:13pm |
In most of the newer versions of P series (e.g. 1994 onwards) You should find five wires that form the connections on the primary side of the tx - (grey, blue, white, black, purple). I can't remember for sure off the top of my head which way they are connected, so I won't comment - but if anyone needs to know I'm happy to check.
Cheers Rex |
Tweet
