12" bass horn |
Post Reply | Page 12> |
login4
Old Croc Joined: 03 April 2006 Location: Wales Status: Offline Points: 1552 |
Posted: 13 December 2006 at 2:32pm |
Here is something i came up with tonight, iv been thinking of trying to design something easy to make, here is a pic of a ruff scetch, i was also thinking of making it quite narrow:
What do you think? |
CELTIC SUBSONIC SOUND SYSTEMS
TDA-Audio
Registered User Joined: 11 February 2005 Location: Russian Federation Status: Offline Points: 294 |
EM - quak
Nigey-C
Registered User Joined: 06 February 2006 Location: Grimsby... FISH Status: Offline Points: 1342 |
Punisher!
djstefanos
Old Croc Joined: 18 November 2005 Status: Offline Points: 2355 |
add another piece and it will be a billfitzmaurice cabinet
login4
its based on a ciare design but with an extra fold at the begining, just a scribble at this point tho...
odc04r
Fairly modellable design, access to the securing the driver might be a
problem. Flip the piece of wood that the driver is mounted on and
extend it and you pretty much have a punisher on your hands.
login4
ye i see your point access will be a big problem
jethrocker
Old Croc Joined: 07 June 2006 Location: Chiapas, Mexico Status: Offline Points: 1942 |
Just change the dimensions a bit around the throat area and an access panel on the front flare section should be possible so you can drop the driver into its chamber from there.
Rear chamber looks huge on this sketch though?
COWFOOT
Registered User Joined: 26 September 2005 Status: Offline Points: 1088 |
Couldn't the access panel/ panels be located like the ones for the Labsub or Punisher?
login4
ye the plan was to have a side access pannel, but ye the rear chamber is way to big
DJ Vencenzo
Registered User Joined: 20 May 2007 Status: Offline Points: 18 |
that looks like u used Autodesk Inventor....nice.
Disco Stu
Old Croc Joined: 03 March 2005 Location: United Kingdom Status: Offline Points: 2487 |
Hi I designed something similar to this but it looked like this
The cab is 600mm high and 762mm deep
I experimented with different widths and it seems that about 500mm is OK but the wider you can go the better for extension to 40Hz being the goal - I tried the Ciare 12SW and Delta12LF drivers - it has a fair amount of wobble in the frequency response - and a high compression ratio 1:4 or thereabouts
If you use a 10" driver the horn actually works better - lower compression ratio - you could also give the horn extra length to try and get higher efficiency - like so
All you need to know is:
Sensitivity + Power Handling - Power Compression = Max Output My acts: www.myspace.com/thebowiexperience www.myspace.com/scheisseelektronisches |
