12" Cast horn flair/ Billet coax mid top |
Post Reply | Page 12> |
feliz
Registered User Joined: 23 April 2012 Location: brighton Status: Offline Points: 108 |
Posted: 22 August 2016 at 11:26pm |
In a couple weeks i will be starting my college project which means a £600,000+ workshop and composites facilities, so im looking for interesting stuff to make with metal or composites.
thinking that some fiberglass MT 122 horns or similar would be a nice project, any thoughts/ideas welcome (honestly anything metal, fiberglass or carbon that would be cool to make.) Edit: How about some billet 6.5" mid tops
Edited by feliz - 05 September 2016 at 8:49pm |
doller
Young Croc Joined: 19 July 2014 Location: japan Status: Offline Points: 509 |
I see that now they can 3d print green sand casting molds. solid aluminum 12inch porn horn would be cool. Aluminuim is everywere I am casting at the moment. Free material recycled.
Darkstar
Registered User Joined: 08 October 2014 Location: Italy Status: Offline Points: 326 |
Sent you a PM.
Bass =/= Enough
feliz
I was wondering about the sound of an aluminium horn flair, if Tony Andrews's thoughts are true it would sound like a tin can.
_djk_
djk
feliz
Daaam i could try something like this, there's facilities for casting.
doller
you may be rite on the tin can thing. I just think that maybe it needs to be 5mm above in thickness. Good luck casting those babies. cost as much as your workshop. nearly.
Casting is great fun. I am onto bronze now. Try it even if it has nothing to do with speakers. |
Sapro2
Registered User Joined: 31 January 2015 Location: Somerset Status: Offline Points: 354 |
Thin aluminum WILL sound like a tin can. Just find something made from thin alumninium and give it a tap with your knuckles. It will not be dull and damped as a speaker box should be.
Splat Soundsystem
Baby Sham pram Soundsystem Sapro - SoundCloud https://soundcloud.com/sapro DJ Sapro. West country free party DJ and Producer. |
jbl_man
Yup,needs to be at least 5mm minimum thickness,10mm would be preferable....going to weigh like an elephant by the time you have added the driver and a cabinet....do you actually want to be able to move it?
Just try lifting the old cast 2inch exit horns from the 1970's,they were heavy enough,let along a 12inch. |
feliz
I guess the tony andrews mindset was right, "if its made of aluminium, guess what its going to sound like a tin can".
all bass
So if cones are made from paper, do they sound like a tree? Edited by all bass - 30 August 2016 at 1:10pm |
bitSmasher
Old Croc Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2295 |
Some do bark
