  New Posts New Posts RSS Feed - 12' first  scoop :)
12' first scoop :)
ddrm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddrm Quote  Post ReplyReply Direct Link To This Post Topic: 12' first scoop :)
    Posted: 07 February 2012 at 2:59am
Hi
Sorry for my bad English
I have pair of shitty speakers 12' 300W 8 ohm, they have low BL and EBP but i really want put them in super scooper :) In the future want build few scoops with good speakers, but now i have no money. What do you think ?
Fs - 22,9285 Hz
Fs Added Mass - 18,4353 Hz
Fs Known Vol - 0,0000 Hz
Added Mass - 41,0000 g
Known Vol - 0,0000 L
Diameter - 257,0000 mm
ZMax - 41,9732 Ω
ZMax Added Mass - 40,0253 Ω
ZMax Known Vol - 0,0000 Ω
Z F1F2 - 16,8943 Ω
Re - 6,8000 Ω
Rms - 6,3359 ΩM
Qms - 1,7047
Qes - 0,3296
Qts - 0,2762
Cms - 0,6427 mm/N
Mms - 74,9734 g
BL - 14,9283 T.m
VAS - 241,4860 L
dBSPL - 91,4834
L 1kHz - 2,1708 mH
L 10kHz - 0,7138 mH
CAS - 1,729390E-6 m5/N
RAS - 2354,4960 Ω A
MAS - 27,8609 kg/m4
RAT - 14533,1900 Ω A
SD - 0,0519 m2
LCES - 143,2197 H
CMES - 336,4228 µF
RES - 35,1732 Ω
MMD - 68,2861 g
RMT - 39,1087 ΩM
eta - 0,8479 %
ZMin - 7,9262 Ω
ZAVG - 23,5559 Ω
Pe - 300 W
Ze - 8 Ω
Le - 1,3736 mH
Voice coil diam. 50 mm
Voice coil layers 2
Voice coil length 25,0 mm
Xmaxlin(+/-) - 7,5 mm
Diam. of magnet 156 mm
Weight of magnet 2780 g
Total weight 5900 g
Edited by ddrm - 07 February 2012 at 3:04am
JR.junior View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 07 February 2012 at 7:58am
S1 is greater then cone Sd!! hehe
ddrm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddrm Quote  Post ReplyReply Direct Link To This Post Posted: 07 February 2012 at 5:55pm
I change S1 and S2
What do you think ? This speaker can handle scoop/mini scoop ? Now it's working  in 3way DIY BR box
Edited by ddrm - 07 February 2012 at 6:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 07 February 2012 at 7:38pm
You have only 12" driver, so build proper suitable scoop for it.
Here you go..
Eminence 12" Scoop.
