12" Kick/LowMid 90-600 Hz Cabinet? |
Diaz
Registered User Joined: 09 November 2011 Location: SBG | Austria Status: Offline Points: 36 |
Posted: 29 May 2016 at 5:46pm |
Hi, im searching for a compact 12" Cabinet to be used with my Oberton 12B450.
It should have max output & clarity between 90-600 Hz. Underneath i use my EV T18 (w/ PD186) as Kickfills from 65-90Hz. From ~550 Hz upwards i use a 2" Selenium D405. Also on Hornplans i only could find Cabinets that are good from 200Hz upwards (mainly horn concepts). All the 12" Bass cabinets i could find only play till 150hz max. What about Bass Reflex Cabinets? Thank you in advance. |
Shortrope
Get on Winisd and design something for yourself, it's not to difficult.
Diaz
thank you for your fast answer. what do you have to pay attention with?
you design the box around the speaker with the t&s parameters an the volume given? i would love to have a design where i can put the 12" and the 2" in one cabinet that also fits my needs. |
Shortrope
That's pretty much it, there's lots of info in the help section once you've downloaded it. |
