12" sub idea |
Edd Jordan
Young Croc Joined: 10 January 2008 Location: United Kingdom Status: Offline Points: 1364 |
Posted: 04 September 2011 at 3:03pm |
Hi all just putting up an idea for a sub my mate wants for his bed room.
drum and bass and dubstep is his bag, just wondering what you think of this as a design. Eminence Lab 12" driver in a 80lt box 40cm x 40cm x 50cm tuned to 28hz with a bass port out the back, cut off at around 90hz dosnt look to bad in winisd. any one had any experience with the lab driver?? Doesn't have to be killer loud but nice and flat and controlled bass is what he is after. |
infrasound
Old Croc Joined: 13 May 2011 Location: Brizzle Status: Offline Points: 2276 |
He will need a hefty amp if he wants it to go loud, but I have heard those LAB12s in reflexes and they do the business in small rooms!
Have you tried simming with a slightly larger enclosure? 100lt maybe?
infrasound
Also may be worth looking into the ciare 12.00sw
MarjanM
BMS 12S330 will give you better results.
Edd Jordan
Any idea where to get hold of the Bms 12s330 and the price? also going to make it active with one of these (maybe)
Like i said before it doesn't have too be crazy loud. hes only got a small room and one of these in a decent sized lounge with 500watts through it is going to be easily loud enough. any one got any good sources for plate amps? |
MarjanM
Contact Tony Wilkes here on the forum. He is the UK BMS guy.
Edd Jordan
of course Mr Wilkes.
cheers
Edd Jordan
any ideas on plate amps, anyone?
technofreak
Registered User Joined: 24 August 2008 Location: Estonia Status: Offline Points: 74 |
Hi, Both plate amps seem to be good - Dayton has parametric EQ, Bkelec has variable phase and balanced input. That's about the differences. I personally would choose Dayton, for the EQ, but in some situations (sub farther away from mains or bandpass enclosure) variable phase would be more beneficial. As for the box, I'd tune it a little lower - around 22...25 Hz to get that real subbass. Then use EQ to compensate for drooping low-end. In the end you get some ~105 dB at 20 Hz and ~110 at 30 Hz - that's without room gain. (I've been contemplating similar design myself, primarily for freq-s below 45 Hz, which is where my main speakers start dropping off.) |
Edd Jordan
thanks for the advice. yeh iv all ready chosen a different driver going for the BMS 12s330 tuning it to around that and the dayton dose look good. going to put my plans up soon. my mate wants one but im going to go ahead and build it before he can afford it because if he dosnt want it ill have it.
