12" Tapped horn |
Post Reply | Page 123 9> |
colint
Old Croc Joined: 06 October 2007 Location: United Kingdom Status: Offline Points: 5222 |
Posted: 19 December 2009 at 5:42pm |
As I am lucky enough to get hold of loads of free MDF I thought I'd have a go at building a tapped horn, I quite liked the 12" version posted on here a while ago (MTH30) so I've spent today chucking one together!
the th is supposed to be loaded with a PD 12SB30 driver but the only 12" I have at the moment is a 20 year old Mckenzie 200watt (400watt cont) jobbie.
I've just powered it up and to be honist the amount of bass out of such a small box scared the crap out of me (and that with the wrong driver driven by one side of an HH 500D) so I think I may well build another tomorrow and buy the correct drivers!
Edited by colint - 19 December 2009 at 5:52pm |
djshaney
Young Croc Joined: 12 May 2009 Location: middlesex Status: Offline Points: 830 |
very nice build mate
you willing to share a plan? as im looking for something similar for at home...
djshaney
apologies just reread your post
Little Jim
New Member Joined: 19 August 2007 Location: United Kingdom Status: Offline Points: 1 |
Hi, chaps
How did you get the paint finish?
colint
I used a radiator roller with tuff cab paint (adcrofts)
still some filling and more coats to add 6 in total.
djshaney
what you gonna be using it for mate? like music style and.. at home? or playing out.
cheers
colint
Well! today I've used it to piss off my neighbors? Lol
I'm building a small system for my son in law to do disco work with (he's just starting up) the idea is to use 2 on these with a 1 x 10" + 1" comp on top of each which should make a nice sounding, portable & powerful system. (forgot to add he plays anything from 70's stuff to drum & bass)
I've had a bit of time to play with it now and I have to say the bass really is very good but it's only had abput 250watts put into it so far but very pleased with the results.
All it's cost me so far is £1.80 for the t-nuts! cheap box eh? PD drivers are next and have been quoted £90.00 each for them so still cheap for a 400watt bass cab
assuming all works well over a period of time then I'll re-build them in birch, and I'm also going to build one for my telly system! Edited by colint - 19 December 2009 at 7:42pm |
djshaney
sounds good!
whered you get all the free mdf from? well jealous prefer it to birch personally (i must be mad! but there we go)
_djk_
Thanks(1)
http://forum.speakerplans.com/another-mini-tpped-horn_topic31691_post316090.html?KW=PD+12SB30#316090
| 40 Hz Tapped Horn
Def_Const |Horn Dimensions
a1 = 150e-4; |Area at throat (cm^2) a2 = 250e-4; |Area at rear of driver (cm^2) a3 = 1300e-4; |Area at front of driver (cm^2) a4 = 1400e-4; |Area at mouth (cm^2) l1 = 10e-2; |Distance from throat to rear of driver (cm) l2 = 240e-2; |Line distance from rear of driver to front of driver (cm) l3 = 25e-2; |Distance from front of driver to mouth (cm) } Def_Driver 'Dr1'
| PD.12SB30
Sd=530.9cm2
fs=50.238Hz Qes=0.316 Qms=5.024 Vas=58.945L Re=5.493ohm Le=1.773mH system 'S1'
Driver Def='Dr1' Node=1=0=3=4 Waveguide 'W1' Node=2=3 STh={a1} SMo={a2} Len={l1} Conical Waveguide 'W2' Node=3=4 STh={a2} SMo={a3} Len={l2} Conical Horn 'H1' Node=4 STh={a3} SMo={a4} Len={l3} Conical Edited by _djk_ - 19 December 2009 at 8:13pm |
djk
_djk_
Same design in Hornresp, but in 1Pi (along wall) rather than 2Pi (middle of room).
djk
colint
I drive a truck for a living these days, one of the places I go to is a new shopping center which the builders are now leaving and they keep chucking stuff they don't want? so far I've had about 10-12 full sheets and 20 or so half sheets all unused.
the crying shame is I just missed half a pack of 18mm birch that went in a skip still on it's pallet, wasn't best pleased? but it's suprising what people chuck away on building site and in skips
bit pikey but it save me a fortune!!!!
Sheggy
Old Croc Joined: 23 May 2008 Location: London Status: Offline Points: 1989 |
I'm liking this very much. How does the horn length compare to the full length TH?
BTW I made a 12" TH a while back and its no good indoors but outside as part of a small 3-way rig with the sub up against a wall running from 30-80 Hz it puts big grins on faces - just sounds lovely! S |
