12 V and mains Inverters... |
Post Reply | Page 12> |
BrightonJake
Registered User Joined: 15 May 2011 Status: Offline Points: 46 |
Posted: 17 May 2011 at 12:24pm |
Hi,
I am new here and would like to say hi to everyone here. Some fantastic rigs and great looking works in progress. I will be launching a new website soon and will post up some of my own pics. I want to start a discussion on inverters. They are often nasty things in terms of contributing noise to a system and I have found this especialy true when using portable systems with dubious or nonexistant ground connections. I have taken to using an earth spike (rod of metal with a good electrical connection to a length of decent cable), attached to the ground connection on my rigs. It's yet another bit of kit (weight) to carry around, but of great importance when using 12V - 240 V inverters to run laptops, decks etc. What are people's experiences with inverters? there are a wide range out there and the efficiency ranges from sub 50% to well into the 90's. Price also obviously roughly corrolates. It's often the case in my experience that only a small amount of power is needed at 240 v if the rest of the setup is well managed, so are there any good tips on fairly moderate power full sinewave inverters for good prices? What are people's expereince with mains hum reduction (when using nverters) and noise reduction generally with portable rigs? J |
portapartyman
Registered User Joined: 19 April 2010 Location: Norfolk Status: Offline Points: 169 |
Hi
I run a true sine wave inverter on my Portable sound system www.theportaparty.co.uk We have just built MK2 which comprises of 2x technics 1210s a 4 channel mixer, laptop, eq and a reasonable switchmode amp (525 @4ohms x2). Just managed 11 hours this weekend at Bearded theory Never had a problem with any pure sine inverter we've used (noise wise). We've had issues with volt drop (obviously) but nothing a larger bank or cap can't sort out. We use a Waeco or Domino. You might want to use some sort of gnd looping if its the laptop creating hum. If the hum is there with only your amp and speakers plugged in you need a different inverter. That noise you can hear could be damaging components in your equipment that a earth stake will never sort. |
slaz
Well I've actually successfully used a cheapy 350W "modified" (yeah, it ain't arf modified - had it on the scope at my mates place - basically a square wave with a bit of holes and spikes) ..... but it works quite OK with just a decent quality hi-fi amplifier (oldish Pioneer class AB 50W + 50W thing) .... reasonable run-times with a 45Ah car battery. No earth loop or other noise problems ...... that was in conjunction with a mixer run directly from the 12V DC. The only thing that concerned me a bit when I first tried it was a slightly "different" "buzz" from the amplifier's transformer - but its never actually caused a problem. This could be just luck of course :-) I'd guess the 230V drain would be _much_ less than its rated 350W ..... never tried it with something a bit more demanding 230V-wise .... |
infrasound
Old Croc Joined: 13 May 2011 Location: Brizzle Status: Offline Points: 2276 |
whats the difference in efficiency between pure sine and modified sine wave inverters? Does the difference in circuitry used between the two give drastically different efficiencies?
slaz
Couldn't tell you mate .... google should be your friend with this .... but I'd _guess_ that if anything the pure sine wave ones would be _less_ efficient, as the circuitry that shapes the output will probably be throwing away some power as heat .... OTOH the _overall_ effiency might be similar or better, as e.g. an amplifier's transformer/rectifier might chuck out extra heat with a "modified" power input. |
S DeXter
Young Croc Joined: 12 May 2008 Location: Moon Status: Offline Points: 1268 |
Anyone used these ones?
http://www.caravantechnology.com/200W-12V-Cotek-Pure-Sinewave-Inverter-P66C17.aspx |
Enjoy your self...... It's later than you think.......
JohnnyPyro
Old Croc Joined: 17 November 2008 Location: London Status: Offline Points: 2083 |
Jake ... i would go for a well branded make .. Mastervolt , Victron, Xantrex & Waeco .. have fitted hundreds of these and the real cheap nasties which i would never use .. i use 2 Mastervolt 4000w combi inverter on my boat .. in that game .. you really do get what you pay for .. you can pick these up 2nd hand on ebay .. so you wont be paying top dollar .. a 2nd hand branded one will be far better than any brand new chinese knock off .. the amount of them that i have seen catch fire/ burn out laptop charger s etc is beyond belief
Powered by MC2 & XTA |
BrightonJake
Cheers John. I will take these recommendations when chosing. I am a little way off deciding how much AC in need, but excellent to have some good brands to start with. :) |
amlu
Young Croc Joined: 30 November 2009 Location: london Status: Offline Points: 740 |
Thanks(1)
bought a one metre ground spike in screwfix, cut it in half, fits easily in a box where i carry my cables.
had a good amount of hum reduced when using it. |
fraction
Registered User Joined: 24 May 2011 Location: UK Status: Offline Points: 15 |
I've got a powermaster pure sine wave 1500w inverter on my boat and it's rock solid. It's also really efficient compared to the cheap crap ones.
That said, at around a grand it's a bit overkill for a soundsytem. Edited by fraction - 02 June 2011 at 3:16pm |
fatty jee
Registered User Joined: 24 June 2010 Status: Offline Points: 36 |
On the subject of mixers etc... and inverters, can anyone tell me how much power 2 x numark cdj and a numark mixer will use? What size inverter will i need, pure sine wave seems to be recommended, cheers
amlu
do not know about numark, but 2x pioneer cdj200 and djm300 suck around 40 watts.
its worth investing in a energy usage monitor... one of those for example - http://cgi.ebay.co.uk/PLUG-ENERGY-MONITOR-SAVING-ELECTRICITY-USAGE-METER-/140571456280?pt=UK_Gadgets&hash=item20bab63318 little gadget for 10 quid shows voltage and connected load. i`m using a 300w victron pure sine wave inverter... got bit of noise problems, but managed to get around by powering inverter from separate battery, using a 50cm ground spike, grounded to aluminium suitcase with amps in. tried using ground loop isolator but no luck. |
