12 V and mains Inverters... |
Post Reply | Page <12 |
BrightonJake
Registered User Joined: 15 May 2011 Status: Offline Points: 46 |
I like... good idea. WIll buy one for sure.
Yes - I have taken to running an inverter off a third battery where possible (weight issues aside) and didn't need an earth spike for that setup. I am still investigating the causes of the hum heard when inverters are used. It is almost certainly earthing related, but I would expect that it is mainly down to eaither an earth loop or most likely the fact that I have pitifully smal cables running power to my amps. The current is very high in 12 V systems, so the coper to the power (at least) needs to be rather on the chunky side to avoid voltage drops... will report back if I can back anything up with experimental results. |
fatty jee
Registered User Joined: 24 June 2010 Status: Offline Points: 36 |
Cheers Amlu, useful info, will look at energy monitor and powering inverter from separate battery
