  New Posts New Posts RSS Feed - 12 volt bike sound systems showcase :)
Tubrog40 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tubrog40 Quote  Post ReplyReply Direct Link To This Post Topic: 12 volt bike sound systems showcase :)
    Posted: 28 January 2014 at 1:32pm
Hi all.
Greetings from copenhagen.
I'll just post a couple of images of our sound bikes for your pleasure :)
The first one is called the obelisk:
Sub:  4 x PD154 4ohm i isobaric mono configuration (4 speakers in - two out of phase)
Top:  1 x 10" p.audio sn-10mb, 1 x 8" p.audio sn-8mb, 1 x 1,75" bullit tweeter p.audio pst-545
Amps: 1 x 3000 watt class t amp at 1 ohm, 1xmtx280 2x140 watt.
Filter: mini disp 2/4 way set to three channels + passive between 8" and bullit at 3500hz with 12 db slope. + behringer xenyx 302 usb mixer for input and volume + FM and wifi audio reciver.
Power: 1 x agm 200 amp battery, 1 x 2 fahrad capacitor, 25m2 cables to amps, 12 volt usb power station. -
Battery life:  +10 hours at full power
Sound level:  around 100 db
Mobility:  Very low - Total load exceeds 300 kg + attached trailer with battery.
Bike: Reinforced 3-wheeled, 5 gear cargo bike with reinforced rims and bearings + 2 wheeled trailer.
Normally used for: Small concerts (if alone), demos, popup parties, video shoots etc. - Works for crowds of up to 2-300 - depending on purpose.
Edited by Tubrog40 - 28 January 2014 at 1:36pm
amlu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amlu Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2014 at 10:14pm
old version of my system, here stationary and unpacked but its possible to play when on the move.
been taking my system to a london critical mass couple of times but its a really really hard work.... weights around 50 kilos plus trailer and i got 10 kilometers to cycle to get there...
110ah battery is a killer :-)
app View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote app Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2014 at 10:41pm
Looking good,both of em!
 ^^Have you been happy with xenyx 302?
The local bikeshop sells christiania bikes,have been thinking if theyd let me borrow one when summer comes.Sorta promotion to them too,drivin around town with sound blastin...
I know the owners semi good as their son is a skateboarder and thats where I buy my cinnamonrolls when I buy some.The christiania bikes are cool!
"what!?"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tubrog40 Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2014 at 8:39am
Actuallly - we have three 302's, and we have been happy with them - even though we could use a few more in/outs
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2014 at 8:50pm
There are a bunch of photos on my Facebook page....
preview popup won't load for me so hope this works.....
Our system is 2 trailers, linked via radio. Each has 1x MTH30, loaded with Fane Sovereign 12-500LF, and 1x Tannoy V8, powered from Sure 2x300w amp module and 300 watt 12-36v upconverter. Crossover board from XKitz splits bass off at 100Hz and highpasses at 50Hz. Powered from 12V 38Ah Yuasa gel cells, total weight 70Kg per trailer. Booms it out!
Edited by studio45 - 03 February 2014 at 12:51pm
app View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote app Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2014 at 9:12pm
^Niceness!
Thumbs Up
edit.xkitz stuff seems interesting,thanks for that...
edit2.Which crossover board youre using?
Edited by app - 29 January 2014 at 9:19pm
"what!?"
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2014 at 12:24am
The only one they do, there are two boards in each amp pack, the first one splits the signal at 100Hz and the second highpasses the bass signal at 50Hz (and has an unused lowpass section).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tubrog40 Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2014 at 6:13pm
Heres a link to our 5 sound systems:
Stereos:    http://www.morfar-sound.dk/main/system_specs.htm
Homepage:  http://www.morfar-sound.dk
Edited by Tubrog40 - 02 February 2014 at 6:14pm
alphabetikal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alphabetikal Quote  Post ReplyReply Direct Link To This Post Posted: 03 February 2014 at 11:50am
300KG??? WOAH
bitSmasher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitSmasher Quote  Post ReplyReply Direct Link To This Post Posted: 03 February 2014 at 10:45pm
My legs ache thinking about that sort of load!
Amlu and s45, your rigs are beautiful - always impresses me to see them in use, you've both struck a good balance of practicality and size
Hopefully I'll be buying a tricycle this weekend, should have a bike system ready just in time for winter! :[
