  New Posts New Posts RSS Feed - 12 volt DBX Driverack on Ebay
JohnnyPyro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnnyPyro Quote  Post ReplyReply Direct Link To This Post Topic: 12 volt DBX Driverack on Ebay
    Posted: 14 February 2012 at 7:29pm
Just stumbled apon this while browsing the car audio gear http://www.ebay.co.uk/itm/DBX-Driverack-260-Pro-Audio-12V-converted-/330684154929?pt=UK_In_Car_Technology&hash=item4cfe4fc431 .. nothing to do with me .. might be of interest to you guys
rebellion_soundz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rebellion_soundz Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2012 at 9:34pm
that's sick man never thought dbx will do thinks like this?
dont live in the past, cos you might not get to the future......
slaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slaz Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2012 at 10:42pm
Most likely a one-off custom job. OK for a vehicle-mounted system of some sort .... no real use for a portable 12V system that I can think of .... 19" rack mount + chunky great XLR connects + very likely heavy power consumption.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rebellion_soundz Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 2:17am
is there no way you could make sumin so the power aint consumed as much?
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 2:25am
That is the twin of the one I had. It was converted by a trusty source and not by DBX. I know the seller too and he's cool.
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 2:27am
Oh and power consumption wasn't that bad, certainly didn't notice much difference between that and a native 12v processor.
Calculus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calculus Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 6:52am
alot of things are 12v dc inside that take iec kettle lead type connectors you can by pass the power supply bit internally if you can supply a stable enough voltage without... that would be my worry for this with a battery system rather than power consumption... Interestingly you can use found computer powersupplies to use your 12v amps off main aswell but that is a different story.
Always a compromise, You can't have everything...
Where would you put it all.
infrasound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 9:07am
All you need is a £15 buck converter and some basic soldering skills Thumbs Up
slaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slaz Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 9:25am
Hmmm .... there's usually a bit more to it than that - if you're doing a thorough job. Do you need extrra DC de-coupling ? What about the voltage tolerance range ? Earthing issues ? Alot of audio gear gear like that will use multiple DC voltages internally - for stuff like LEDs, displays etc. .... so not so straightforward if you also want power economy. The stuff designed for cars generally makes no concessions to power economy - it assumes you have plenty of 12V available .....
Its all do-able via DC-DC converter ICs of course ....
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 9:42am
You would have thought so, but of the kit I've looked at - FBQ1502, FBQ800, DCX2496, DRIVERACK260 it's basic linear supply and zener based regs (extra high drop). All the housekeeping supplies are created on board, after the rail regulation - so you don't need to touch them.
As you're just bypassing their linear psu, earthing is pretty simple. Never needed a decoupling cap with the converters I've used, they switch high enough not to be an issue. Would be easy enough to implement if you needed to though Thumbs Up.
In the interests of power consumption, I've managed to undervolt one circuit - running it off +-6v instead of the normal +-10v. Luckily the smaller Vregs and opamps on the board could easily handle it. Havent measured the decrease in current to the whole board, but would imagine its around 40%.
Forum Software by Web Wiz Forums® version 10.11
