  New Posts New Posts RSS Feed - 12 volt DSP modules
12 volt DSP modules
PolymorphicMark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PolymorphicMark Quote  Post ReplyReply Direct Link To This Post Topic: 12 volt DSP modules
    Posted: 10 October 2010 at 9:28pm
Any one come across any 12 volt crossover, delay or DSP modules.
Free to do what i WANT
audiomik View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiomik Quote  Post ReplyReply Direct Link To This Post Posted: 10 October 2010 at 9:33pm
Try the 'Mini DSP' thread?
http://forum.speakerplans.com/mini-dsp_topic42069.html
Mik
Edited by audiomik - 10 October 2010 at 9:34pm
Warning! May contain Nuts
plus springs, washers, screws, etc, etc.
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 12 October 2010 at 1:53am
The Ultradrive can be modded for 12v use. I once installed one in a system for a friend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PolymorphicMark Quote  Post ReplyReply Direct Link To This Post Posted: 12 October 2010 at 2:56pm
So Sam, are you saying the ultradrive uses 12 volt the other side of the transformer or are the mods more complex than that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiomik Quote  Post ReplyReply Direct Link To This Post Posted: 12 October 2010 at 3:31pm
There are a number of threads over on the DiyAudio Forum discussing various mods to Ultradrives which may be of interest?
However as far as I'm aware the Ultradrive has a number of different voltage supply rails, at least 2 of which would need to be +/- 15volts to enable the specified analog outputs to work correctly.... together with suitable 'Digital' supplies - all from a Switch Mode PSU
Internal pics and many discussion posts at:
http://www.diyaudio.com/forums/digital-line-level/15943-behringer-dcx2496-digital-x-over.html
Mik
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2010 at 4:47pm
I'm pretty sure thats the case. I got it premodded and just installed.
djslacka View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djslacka Quote  Post ReplyReply Direct Link To This Post Posted: 14 October 2010 at 2:46pm
how much roughly would this mod cost for someone to do?
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiomik Quote  Post ReplyReply Direct Link To This Post Posted: 14 October 2010 at 2:52pm
In time plus parts, to replace the existing Switchmode PSU completely with suitable DC-DC convertors, probably about the same as the initial cost of the Ultradrive.
Plus there would be absolutely no manufacturer's warranty for the original product
Mik
