12 Volt Party Pics |
Post Reply | Page <123> |
Saturnus
Old Croc Joined: 13 July 2010 Location: Copenhagen Status: Offline Points: 2025 |
The problem with inverters isn't with low powered stuff with almost constant current draw. For that inverters are actually quite efficient. Usally about 90% but you have to add the conversion loss in the 230V appliances as well, so total you should probably just add 20% or so to the power consumption. The problem is with amplifier and other high power variable loads like lighting is that the inverter in this case "sets" itself for a much higher constant current draw than the actual average power consumption, so efficinecy can drop as low as 65%, and with the add conversion in appliances that can account for up to 40% added power consumption. So buy as small an inverter as possible, since efficiency is best when power consumption is about 80% of the rated capacity, for all your low power appliances if it's not possible to run them directly on 12/24V, and run your lighting and amplifiers directly on 12/24V. |
amlu
Young Croc Joined: 30 November 2009 Location: london Status: Offline Points: 740 |
Got two batteries,
one 115 Ah running pure sine wave inverter, 2x CDj200 and DJM300 mixer take around 40 watts. Had it running off battery for 10 hours and there was still some power left. "Big rig" running 4x tripath amps takes 4-5amperes. 110Ah battery lasts for good 10 hours, solar panel helps too. |
alphabetikal
Registered User Joined: 20 May 2010 Location: UK Status: Offline Points: 217 |
amlu - your system is SWEET!
portapartyman
Registered User Joined: 19 April 2010 Location: Norfolk Status: Offline Points: 169 |
Here is a picture of the Porta Party @ Bearded Theory last weekend. We've rebuilt it and made it louder which means we can command our own dance floor cutting out bleed from the other stages.....apart from if you're the DJ which is a little annoying but essential to keep power consumption to a minimum
portapartyman
And here's a close up of the Porta Party Crew. Dressed up for the Punk n Ska set (above)
toiminto
Registered User Joined: 16 June 2009 Location: tampere,finland Status: Offline Points: 48 |
http://vimeo.com/12750843
some video from our party groups 6y party last summer, preparty during the day with 12v system :) 1" celestion, 10" p.audio, and 15" kappalite lf in an ugly demo box. 12" isnt in use ;) Edited by toiminto - 31 May 2011 at 8:02am |
http://soundcloud.com/toiminto
SamV
Old Croc Joined: 21 October 2008 Location: London Status: Offline Points: 8711 |
Some Videos
May Day May Fayre in Mayfair: http://www.youtube.com/watch?v=OpmIvomCSY0 NYE Greenwich Foot Tunnel Party: http://www.youtube.com/watch?v=duX86Fhq2M8 May Day @ Bank of England: http://www.youtube.com/watch?v=E4kzikiRHbA Had loads from the Circle Line Parties and Midnight Cricket we've been doing for the last 10 years but cannae find them :( Here's some pics :) I think they count? |
rich_gale
Old Croc Joined: 18 February 2008 Status: Offline Points: 2697 |
brilliant:)
Plaguesguitarist
Old Croc Joined: 30 April 2009 Location: Lincoln, Earth Status: Offline Points: 2238 |
Those two scuffers look pleased to be there.
edit: Scuffers = rozzers. I spend way too much time reading Rogers' Profanisaurus Edited by Plaguesguitarist - 01 June 2011 at 10:26am |
To steal MY sharpie. |
alphabetikal
sam - that beast you got on the bicycle trailer looks absolutely MEAN!! whats the specs of it?
a
SamV
At that time it was 600w on bass, 900w on mid top. All rms. Bass was run from a switchmode Class D amp at 4r with 1.8kw on tap. Tops were run from a Class GH amp at 4r. Battery was a 120ah high end Deep Cycle SLA. Run time was 4hrs at full, 6 hours at Critical Mass Volume, Almost a full day at mates down the park level, and near a week on television duties lol. That was about 3 or 4 years ago now (ah those were the days...). It was designed purely for Critical Mass but ended getting used for a lot of things including promo work and festivals.
SamV
We were also the only system allowed to carry on playing into the SOCPA zone as it sounded good lol. And most of the time the coppers would give requests.
