12v Amp for Tham 15?? |
Post Reply | Page 123> |
Shortrope
Posted: 09 July 2014 at 8:21am |
I'm not clear on what 12v Class D Amp to use to power my Tham 15s.
Everything seems to be rated at 4 and 2 Ohm but the P-Audio drivers I have are 600w 8ohm. What sort of power Amp could I get away with if I ran the pair at 4 Ohm?? Something like this??
slaz
Well that Vibe would be a decent choice, but obviously those amps are designed for loads lower than 4R. You might also consider a 4ch full-range class D amp (look at Vibe, Kenwood, Pioneer) and use it as 2 channels in 8R bridge mode. Would achieve about the same o/p into your 8R bass cabs, but could also be used as full-range or on mid-top duty (via the built-in filters).
Remember those power ratings are at power source of around 14.4 or 14.8V .... so subtract about 15-20% when using with standalsone batteries. |
Shortrope
Thanks a mill Slaz, that's helpful.
While I've got your attention....would you have any thoughts on how I can control the input for my system? I'll have the Amp for the Subs and a Boominator. I'd like to have a volume control for the lot. Would it be as simple as inputing into a Pot and then splitting to the Subs and Boominator?? Ta!
Shortrope
lutkeveld
Or use a male to female 3.5mm cable with an inline volume control and then split the signal. Look for it on ebay.
slaz
Yeah I've been up against a similar situation. Only answer really is to use some kind of little pre-amp or mixer. Things might go a bit awry if you just use a pot (different input impedances on the boominator and car amp ...... well I suppose it _might_ work if your source impedance is low and the input impedance of boominator and car amp are similar). |
slaz
Yup - something like that. No mention of a sub-sonic filter on that one though - ideally you'd HP at around 40 or so and run the car amp up to about 100 ? Expect a bit less than 200W x 2 into 2 x 8R bridge loads .... with 2 x THAM15 that should make plenty of noise though |
bitSmasher
Old Croc Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2296 |
Thanks(1)
Separate attenuators for both amps imo
I use a similar Pioneer 4ch amp and am really happy with it. If you bridge it to 2 ch you'll get decent output. If you go this far with it, best to get a seperate crossover like xkitz or minidsp |
slaz
Does the miniDSP do delay ? Coud be useful if it does .... sound-all-around boominator + horn-loaded bass cabs might go a bit weird otherwise I'd have thought. |
Shortrope
Ahh Shite hadn't though about the delay aspect! How about making a basic inline High pass filter and using the low pass on the Amp??
Edited by Shortrope - 09 July 2014 at 1:25pm |
Shortrope
Mini DSP does have delay though, could be handy.
Guess I'll just need to fire it up and see what it sounds like. |
bitSmasher
Is it a 2x4 MiniDSP?
If so, how about stereo tweeters, mono 10" then use the 4th channel as an output to your sub... |
