  New Posts New Posts RSS Feed - 12v Amp for Tham 15??
Saturnus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saturnus Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2014 at 10:06pm
Bass is not about finesse. It's about running a lot of juice through the system. I'd definitely go with a power supply rated for at least 30A with a single THAM15 and 50A with a pair.
amlu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amlu Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2014 at 10:39pm
you may experiment with splitting the signal right at the beginning, giving the sub (<80hz or something, tune with your ears) into tham15, and all the rest >80hz, midrange, high to the boominator....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saturnus Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2014 at 7:41am
120hz is the preferred crossing point. (or 121.2hz if you're pedantic).
Edited by Saturnus - 24 July 2014 at 7:41am
Shortrope View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shortrope Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2014 at 7:53am
It's working great with the LPF on the Amp at 120ish and the Subsonic filter at 50.
slaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slaz Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2014 at 10:11am
AAMOI, what amp(s) do you have driving the boominator ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shortrope Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2014 at 10:56am
A pair of Accusafe Maxamp20s and a Mini DSP.
