  New Posts New Posts RSS Feed - 12v system, £200 budget
ZuluSoundsystem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZuluSoundsystem Quote  Post ReplyReply Direct Link To This Post Topic: 12v system, £200 budget
    Posted: 23 April 2014 at 1:08pm
Iv gotta build a 12v system for a mate with a budget of 200
can i have some suggestions to some good drivers and amps batteries etc
ideally would like to have some bass as would probably be used for dance music
help much appreciated cheers =)
For Rinseout Junglist Dub
http://soundcloud.com/warrior_zulu_soundsystem
Gavos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gavos Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2014 at 4:40pm
Try a Boominator...
You can get the divers needed for about £125, that leaves you with £75 for the plywood, ta2020 amp and a 7ah 12v sla battery.
Look for the amps on ebay from china/hongkong, the ta2024 is cheaper but less power.
Im building one right now. Thumbs Up
lutkeveld View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lutkeveld Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2014 at 5:04pm
Or a cutdown Boominator like Gavos suggests or a full blown Halfinator.
mr. doom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mr. doom Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2014 at 6:04pm
How much speaker can you tote around? (size/weight)
How long do you need it to run?
amlu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amlu Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2014 at 10:39pm
good drivers whatever comes up on ebay with high efficiency and possibly neodymium magnets (to save on weigt) and a good price. do not use cheap hifi or car audio drivers efficiency on them is not enough.
alternatively get some second hand pa boxes... will save on building and wood costs.
tool station or local electrician shop for 12v alarm system batteries...
http://www.toolstation.com/shop/Electrical/Batteries/Sealed+Lead+Acid+Battery+12V+120Ah+151+x+99+x+101mm/d190/sd2450/p69745
or ebay and golf cart/mobility scooter batteries, or car garages and car batteries with some life in them
hifimediy for class d high efficiency amplifiers... stay out from cheap car audio amps they will drain any battery fast when used without a car
