  New Posts New Posts RSS Feed - 15" 18" vs kick bin punch plan design best dance
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 1:20pm
Tom: My research suggests mt121 will go down to 120-130 when used in pairs. Which makes sense because mt122 crossover is from 120hz and at that lower freq the horn isn't really directional. So two mt121's side by side is an virtually an mt122 with crossover of 120-130hz.
Not sure about crossovers yet, with this combo there should be plenty of room to play around. I'm really looking forward to tuning it once it's all built!
@Smoore,
Hey mate, love your boxes, saw the picks of them in Tom's thread Clap.
Re having no kicks, just invaders; well yeah i suppose I could but the kicks put the height in the stack which is pretty important. Also, toastyghost said in the invader thread that they're subs and need kick, I respect his opinion. Plus i just love the idea of having kicks Big smile
Originally I was going to go with 4 es18 + 2 mt122 each side but sks01 gave some good advice suggesting this was a whole lot of kick. Just the way he put it you could tell it was honest advice. He suggested that 2 es18 & 2 mt122 per side, with bass underneath was "pretty nice". . Hence the reason for the invaders coming into the equation. The only other mod I've made to the advised combination is starting off with mt121's. This came about after reading the stuff about 2 mt121's cross well 120-130hz and the $ saved here are very welcome. Then if i need too or want I can always build another 12 inch section later on. This would go underneath the mt121 and add some nice height to the stack.
smoore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smoore Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 1:54pm
nice mate :) Sounds like you've got alot of building ahead! Hope it goes well :) good luck!
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 2:04pm
Cheers!
Tocooltom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tocooltom Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 5:00pm
just found this might not be of interest to you but thought it would be helpful to someone searching for plans
phildat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phildat Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 5:52pm
Mt122 plays fine down to 120. Been stated on here many times.
Back in blighty....
Luke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 6:13pm
I used to run mt122's down to 120 no problem, and run my invaders up to 120hz to meet our stasys 3's. having played around with that setup a bit I still prefer the invader/usb/s3 combo, but i would cross the usb's or other kick cabs much lower than 180hz, normally around 130hz for stasys 3's or mt121's.
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2012 at 8:35am
Yeah thanks Luke, was thinking along the same lines.
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2012 at 8:41am
Great Tom, hoping this thread can become a good resource too. Will be modifying accordingly when I get time.
subsystem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote subsystem Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2012 at 12:34pm
Hey Mate
Just wondering if you are up norwich drection .Just moved to the area and started building some 1850 Horns. All good so far.
Would you have any idea of a good place to pick up Drivers in Norfolk
Cheers Man
brooa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brooa Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2012 at 1:36pm
keen ive got some (7) of daves booty bass's (over here in perth) and they do pretty well. if you find your way over here more then welcome to check em out haha but yeah i would look at what drivers you can get then work from there.
edit: we have some reverse loaded with fane 15-600's as sub and normally loaded 15-400's as kicks
Edited by brooa - 05 June 2012 at 1:38pm
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2012 at 2:00pm
Cheers dude, if I'm ever over that way I'll come see ya. luvin the pics  you put up of the doof. that system on the small stage looked wild! I actually talked to arena.lsd on the phone a while back when I started getting into diy rigs, he helped me out heaps!
Post Options Post Options   Thanks (0) Thanks(0)   Quote brooa Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2012 at 6:25am
Yeah for sure man. Yeah Mikey's a good bloke. Always got time for him. He built our booty bass cabs for us. Top notch work.
web department
