15" 18" vs kick bin punch plan design best dance |
Page <123> |
Keen
Joined: 30 May 2011 Location: Brisbane, AUS Status: Offline Points: 404 |
Posted: 30 May 2012 at 1:20pm |
Tom: My research suggests mt121 will go down to 120-130 when used in pairs. Which makes sense because mt122 crossover is from 120hz and at that lower freq the horn isn't really directional. So two mt121's side by side is an virtually an mt122 with crossover of 120-130hz.
Not sure about crossovers yet, with this combo there should be plenty of room to play around. I'm really looking forward to tuning it once it's all built! @Smoore, Hey mate, love your boxes, saw the picks of them in Tom's thread . Re having no kicks, just invaders; well yeah i suppose I could but the kicks put the height in the stack which is pretty important. Also, toastyghost said in the invader thread that they're subs and need kick, I respect his opinion. Plus i just love the idea of having kicks ![]() Originally I was going to go with 4 es18 + 2 mt122 each side but sks01 gave some good advice suggesting this was a whole lot of kick. Just the way he put it you could tell it was honest advice. He suggested that 2 es18 & 2 mt122 per side, with bass underneath was "pretty nice". . Hence the reason for the invaders coming into the equation. The only other mod I've made to the advised combination is starting off with mt121's. This came about after reading the stuff about 2 mt121's cross well 120-130hz and the $ saved here are very welcome. Then if i need too or want I can always build another 12 inch section later on. This would go underneath the mt121 and add some nice height to the stack. |
smoore
Joined: 30 March 2011 Location: N.Devon Status: Offline Points: 574 |
Posted: 30 May 2012 at 1:54pm |
nice mate :) Sounds like you've got alot of building ahead! Hope it goes well :) good luck!
Keen
Posted: 30 May 2012 at 2:04pm |
Cheers!
Tocooltom
Joined: 07 March 2011 Location: London Status: Offline Points: 1293 |
Posted: 30 May 2012 at 5:00pm |
just found this might not be of interest to you but thought it would be helpful to someone searching for plans
phildat
Joined: 29 January 2009 Location: manchester Status: Offline Points: 1066 |
Posted: 30 May 2012 at 5:52pm |
Mt122 plays fine down to 120. Been stated on here many times.
Back in blighty....
Luke
Joined: 06 May 2010 Location: Norfolk Status: Offline Points: 436 |
Posted: 30 May 2012 at 6:13pm |
I used to run mt122's down to 120 no problem, and run my invaders up to 120hz to meet our stasys 3's. having played around with that setup a bit I still prefer the invader/usb/s3 combo, but i would cross the usb's or other kick cabs much lower than 180hz, normally around 130hz for stasys 3's or mt121's.
Keen
Posted: 31 May 2012 at 8:35am |
Yeah thanks Luke, was thinking along the same lines.
Keen
Posted: 31 May 2012 at 8:41am |
Great Tom, hoping this thread can become a good resource too. Will be modifying accordingly when I get time. |
subsystem
Joined: 05 June 2012 Location: Norwich Status: Offline Points: 1 |
Posted: 05 June 2012 at 12:34pm |
Hey Mate
Just wondering if you are up norwich drection .Just moved to the area and started building some 1850 Horns. All good so far. Would you have any idea of a good place to pick up Drivers in Norfolk Cheers Man
brooa
Joined: 23 August 2011 Location: Australia Status: Offline Points: 160 |
Posted: 05 June 2012 at 1:36pm |
keen ive got some (7) of daves booty bass's (over here in perth) and they do pretty well. if you find your way over here more then welcome to check em out haha but yeah i would look at what drivers you can get then work from there.
edit: we have some reverse loaded with fane 15-600's as sub and normally loaded 15-400's as kicks Edited by brooa - 05 June 2012 at 1:38pm |
Keen
Posted: 05 June 2012 at 2:00pm |
Cheers dude, if I'm ever over that way I'll come see ya. luvin the pics you put up of the doof. that system on the small stage looked wild! I actually talked to arena.lsd on the phone a while back when I started getting into diy rigs, he helped me out heaps!
brooa
Posted: 06 June 2012 at 6:25am |
Yeah for sure man. Yeah Mikey's a good bloke. Always got time for him. He built our booty bass cabs for us. Top notch work. |
Page <123> |
Tweet
