15" 8" 1" |
Post Reply | Page <123 |
snowflake
thanks, assume neo version is virtually identical good product but only really usable from 400Hz-2.1kHz
Andy Kos
Neo virtually identical, very slightly different in the lower region, but not much in it, certainly nothing to get excited about. I usually run them from 400hz to 2.5khz and it works fine for me. The dip the response shows just above 2khz isn't as apparent in 'real life' as the test data suggests, partially depending on crossover slope and comp driver you use it with. I have run them 350hz to 3kHz without significant problem, but ends up needing some EQ between 2k and 3k. Edited by Andy Kos - 21 November 2016 at 3:12pm |
