15" reflex cab |
Post Reply | Page <123> |
pk1964
Registered User Joined: 21 February 2008 Location: Warrington Status: Offline Points: 269 |
How high will this play 200 hz ?
mini-mad
depends on the driver really.......
i dont know what i was thinking wen i wrote this most 15" drivers should play "ok" upto 800hz ...ya just wouldnt, theres a few other cabs iv looked at too... Edited by mini-mad - 14 December 2013 at 2:33pm |
pk1964
Mini mad what would you recommend got to go upto 200 to meet my mid cabs, need to build next week help anyone ?
charlynch
Registered User Joined: 24 September 2011 Location: Somerset UK Status: Offline Points: 188 |
A reflex cab will easily go to 200.
If you list what the rest of your gear is, what music you play & how many peeps you want to cover you will get better advice.
generalant
Registered User Joined: 18 March 2012 Location: Bristol Status: Offline Points: 303 |
im after the same sorta thing a 15" relex cab to go above sccops, using fane collosus drivers. Is the sub 15 gona be a better bet than the Fane constructor then?
Porky
Registered User Joined: 03 January 2014 Location: Rochford Status: Offline Points: 106 |
The little rig I'm currently building is based on the DM2 plans but split into separate cabs so I can lift them on my own.
Design uses Kappa 15 LF crossed at 250 Hz. Iirc box is about 120 Ltr gross tuned to 46 Hz. Have the wood cut and ready to build so can't comment on what they sound like just yet. |
king david
Young Croc Joined: 17 January 2007 Location: italy Status: Offline Points: 1324 |
are these plans for 20mm, 19, 18 or 15mm wood? thanks!
Brother T
Registered User Joined: 19 November 2007 Status: Offline Points: 71 |
I have some newly built RCF sub 15s on the bay for sale at the moment.If anyone is interested pm me.Special deal for sp members.
peace and love
Geoff
New Member Joined: 05 May 2015 Location: Bexleyhealth Status: Offline Points: 2 |
How much would it cost to have four made and could they be made from 22 mm birch ply
Geoff
MarjanM
Why 22mm? That is a bit overkill for a 15 inch sub.
king david
...i would still ask what is the thickness of the wood in those rcf plans, may build a pair...
