15" reflex cab |
Post Reply | Page <123 |
krazyneil
Young Croc Joined: 06 December 2007 Location: Bolton ,lancs Status: Offline Points: 1206 |
18mm
GOD TOLD ME TO DO IT !!!!!
stanley dj
Registered User Joined: 19 July 2013 Location: Ireland Status: Offline Points: 154 |
all all i have one done anybody putting wadding inside ? and much ?
Dub Specialist Sound
thanks
bob4
Old Croc Joined: 29 February 2004 Location: Finland/Germany Status: Online Points: 1843 |
have to agree, higher tuning doesn't bring any benefit. I simulated single L15P200AK in a small reflex. if you high pass it BW 8th order at 80 Hz, you can give it the stick until it runs into the thermal limit without exceeding xmax. With 1600 W (rated peak power) it will dish out 127 dB
stanley dj
hi all i have buil one did anybody put any wadding inside ? and much
krazyneil
you should deffo put wadding in, either eggshape the walls or stick wadding all the way round |
krazyneil
that is rcf own plan, just use the different dimensions as listed for your driver , id hazard a guess they know what there doing with there own drivers lol
Norseman
Registered User Joined: 04 March 2013 Location: Torquay Status: Offline Points: 124 |
i am looking to take the 15"s out of these cabs that i have: http://www.bob-audio.com/en/FS252.php and build something similar (single cab per driver) i currently run these over top of two super scoopers, sounds good, but because the BOB cabinets are so tall it makes it a pain to set up by myself, also very heavy. is anyone godo with designing things to a drivers specs? i cutoff at 100Hz for the scoops and run these over top. it also has a 2" compression driver in it with what i assume is an internal passive x-over i will likely put these comp drivers in their own box with the passive x-over in it, or run them spereately with other tops off another amp in the future.... the quoted design above looks pretty good...i suppose it is a question of measuring the box they are currently in but it is trapezoid in nature and i am not so sure on how to calculate the port length and opening size as its a weird design inside from that perspective (shelf between comp driver and the lower part, ports on either side of the comp driver etc etc any help would be awesome |
