  New Posts New Posts RSS Feed - 15" scoops for 2 way setup in small club (reggae)
micha-irieites View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote micha-irieites Quote  Post ReplyReply Direct Link To This Post Topic: 15" scoops for 2 way setup in small club (reggae)
    Posted: 15 October 2013 at 12:15pm
Hi,
I want to setup a small soundsystem to play reggae/dub in small clubs.
40-100 squaremeters
100-150 persons
What I am planning is to build two 15" scoops and to run 2 usual PA tops (15"/1" tweeter) on top of it. Crossover at 110 or 120 hz, active crossover, 2 amps.
I found this plan:
http://www.dancetech.com/index.cfm?loading=pa&pa_loader=181
Does it make sense to run this setup for small venues ?
Do the 2 scooper go deep enough for reggae/dub (around 40 hz)? Or does it make no sense to only operate 2 of them.
And which driver shall I consider? I donĀ“t want to spend more than 200 euros per driver (around 270 usd.
Thank you for your support.
Micha
Edited by micha-irieites - 15 October 2013 at 12:20pm
This page was generated in 0.074 seconds.
