16 ohm soft dome hf driver |
Dj_Alan
Joined: 15 February 2007 Location: Manchester Status: Offline Points: 42 |
Topic: 16 ohm soft dome hf driverPosted: 18 February 2012 at 10:51pm |
what do I (or can it no be done) need to fit to turn a 16 ohm hf driver into a 8 ohm hf driver (so amp see's it as 8 ohms)
now I know the easy solution is to buy an 8 ohm one ,but love the sound from these old jap ones so really want to keep them
Al
kedwardsleisure
Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 1939 |
Posted: 19 February 2012 at 1:20am |
you could rewind it so the 16ohm winding is an 8ohm one.
North Staffordshire |
service dept Steve
Joined: 30 January 2010 Location: S.W.London Status: Offline Points: 1452 |
Posted: 19 February 2012 at 10:53am |
Presumably this is so that your crossover sees the correct loading? In which case simply fit a 16 ohm resistor of a similar power rating to the tweeter in parallel with the tweeter and then the crossover will see 8 ohms.
We are not "they", We are "the others" - http://www.servicedept.co.uk -
odc04r
Joined: 12 July 2006 Location: Sarfampton Status: Offline Points: 1954 |
Posted: 19 February 2012 at 11:18am |
If you have the headroom then a 16 Ohm tweeter will just be harder to drive than an 8Ohm so no problems beside that. As someone else above said a modification of the Xover network will achieve better power matching also. |
Tweet
