  New Posts New Posts RSS Feed - 18 horn HB1805C1
18 horn HB1805C1
gora View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gora Quote  Post ReplyReply Direct Link To This Post Topic: 18 horn HB1805C1
    Posted: 23 January 2009 at 8:58am
Hi all, i am interested to build halfs of HB1805C1
iam looking for some measurement SPL plot for these cabs, experience .... anyone???
next i need to calculate horn response of the hlaf of the cabinet, can someone help?
kiriiz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kiriiz Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2009 at 10:54am
I'm interested too. Somewhere on this forum i heard that this construction produce nice low sound.
gora View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gora Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2009 at 11:07am
any idea how they will sound if we build one half of it ?
the half cabinet will have 80x80x50 ...so the will be very small
asaa00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote asaa00 Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2009 at 9:57am
just finished cutting the pieces, going to assemble a pair this weekend, ill tell you how it goes!
gora View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gora Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2009 at 2:47pm
wow super!
you build halfs of the cabinet or the original design with double 18 speakers?
Paulo Duto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paulo Duto Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2009 at 3:32pm
Hi,
In march 1995 Selenium delivered this plans designed for their wpu1805 driver:
Notice that it's anechoic chamber measurement.
Plans in millimeters:
To me a 1850 is far better.
Regards,
Edited by Paulo Duto - 27 January 2009 at 6:14pm
Paulo Duto
gora View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gora Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2009 at 8:44pm
Originally posted by Paulo Duto Paulo Duto wrote:
Hi,
Regards,
please do you have better images ? these are too small to read the numbers etc
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paulo Duto Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2009 at 1:18pm
Hi
Try with these images:
Regards,
Edited by Paulo Duto - 29 January 2009 at 1:36pm
Paulo Duto
fredos666 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fredos666 Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2009 at 2:22pm
They work well but the 1502 outperform them a lot! We have built both of them...We have 8 of the 1502 and 2 of the 1805. In stack of 4, the 1502 kick and go very low...We use all RCF drivers inside, they give lot more output compare to the original Selenium drivers. We built them on the other way to couple the mouth..
gora View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gora Quote  Post ReplyReply Direct Link To This Post Posted: 03 February 2009 at 8:38am
Hi
Regards,
thanks, i did check the plan the with HB1805B1 ... the cabinet is similar but it has diferent size (its bigger and has probably different angle) with compare of half of HB1805C1
i expect that they will sound different (i hope so Smile)
gora View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gora Quote  Post ReplyReply Direct Link To This Post Posted: 03 February 2009 at 8:42am
here i did find older selenium plans ... HB1805B1 is there too
http://www.selenium.com.br/site2004/downloads/projetos/TRADICIONAIS.pdf
Edited by gora - 03 February 2009 at 8:43am
heinrich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote heinrich Quote  Post ReplyReply Direct Link To This Post Posted: 03 February 2009 at 8:53am
fredo666:
as I could see on that pix on your link provided, marked TMH-1
is that PAS1MA1 on top of the bass bins?
how do this mid top sound...........and how heavy should this be thanks....Smile
and please advice crossover points...........equing etc....
thx
Edited by heinrich - 03 February 2009 at 8:58am
.....power is nothing without control....
This page was generated in 0.064 seconds.
