  New Posts New Posts RSS Feed - 18 inch subs s-audio
djjerom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djjerom Quote  Post ReplyReply Direct Link To This Post Topic: 18 inch subs s-audio
    Posted: 13 May 2017 at 8:08pm
Hello,
I have 2 subs from s-audio 18 inch 800 watt.
Butt the subs are not compleet they don't have a case.
Now i am searching for a speakerplan for these speakers.
http://www.saudio.de/produkte/mia-infra/
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 8:15pm
Do you mean that you have two naked 18" woofers without cabinet?
To get suggestions, you would need to find out the thiele-small parameters of the woofers, or at least the model name. Then someone on this forum might be able to help you.
Don't ask for the original plan of the saudio cab, no one has it, and in general people don't publish plans of commercial cabs that are in production.
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 9:53pm
Impressive, it goes from 28hz to 220Khz!
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote djjerom Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 9:54pm
Dear Bob Thanks for you answer,
I am not searching for the original plan. I understanding that these plan are private.
I have indeed 2 naked subs. The Thiele-small parameters i don't have them. But i searching for these so that sombody help my with som speakerplan.
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 8:33pm
post some pics, someone might recognize the driver ;)
Edited by bass*en*mass - 14 May 2017 at 8:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote djjerom Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 1:43pm
https://www.flickr.com/photos/154755315@N04/34511489332/in/dateposted-public/
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 7:24pm
As you can't directly post pics until your post count is higher, here they are...
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 12:50am
For PA drivers with no T/S parameters:
12's 2 cu ft 50hz
15's 4 cu ft 40hz
18's 6 cu ft 40hz
For better results, have them measured.
Edited by _djk_ - 16 May 2017 at 12:50am
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 6:27am
looks like a generic chinese driver to me (as expected tbh)..
if you want to measure TSP theres lots of info online on how to do that DIY at low budget.
 the mia sub will likely be tuned 40ish hz, dimensions are known, build a prototype and play with tuning? :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote djjerom Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 10:06am
What do you think of building the cubo 18 extendend whit this driver?
