  New Posts New Posts RSS Feed - 18 Sound 18LW2400 & Fane 18" Colossus Prime XS
ROGER D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ROGER D Quote  Post ReplyReply Direct Link To This Post Topic: 18 Sound 18LW2400 & Fane 18" Colossus Prime XS
    Posted: 21 April 2017 at 12:25pm
Friends,
Need your advice on 2 X 18" plans for 18 Sound 18LW2400 & Fane 18"Colossus Prime XS.
Reflex or Horn Loaded, please advice. We are a sound rental company doing Live Band Concerts & EDM Festivals in Stadium & Arenas with a crowd of 5000 and above on most occasions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2017 at 1:46pm
The Eighteen Sound you are considering can work in either a horn or bass reflex. The Fane you are considering is aimed for reflex cabinets not, horns. For the amount of people you are stating you are catering for, it would be best to focus on one type of speaker and buy quantity. Your top cabinets will dictate whether a slew of horns or a slew of reflex cabinets is the best choice pending on how low of a frequency your top cabinets can produce.
Best Regards,
Post Options Post Options   Thanks (0) Thanks(0)   Quote ROGER D Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2017 at 1:59pm
Dear Elliot,
Thank You for your advice.
The Line Array tops we are using start from 60hz
Between the 2 components what will you advice - 18 Sound or Fane.
Yes we will be using only one brand of components only and won't be mixing the two at all.
All our concerts are Bass heavy especially when we are doing the EDM Festivals.
Regards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2017 at 3:12pm
If your tops can reach down to 60 Hz, you are better off with Reflex cabinets as you will have no issues achieving one octave lower. The majority of bass horns on the market take a nose dive under 50 Hz. So it would make logical sense to choose the driver that was designed for a reflex box based on your choices of the two speakers you are considering.
Best Regards,
Post Options Post Options   Thanks (0) Thanks(0)   Quote ROGER D Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2017 at 3:18pm
Thank You Elliot
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2017 at 4:29pm
Roger Drego?
gen0me View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gen0me Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2017 at 5:21pm
For edm I would go for horns. Especially on this scale.
Be carefull with line array tops they may have -few db there.
The best give concrete tunes you want to sound best and tops or at least lf drivers in tops.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gen0me Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2017 at 5:23pm
Any size restrictions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2017 at 5:58pm
Guys, before you continue giving ideas, can we confirm this guys identity?
Roger Drego is a rental company and manufacturer from India that is ripping off other people designs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ROGER D Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2017 at 6:08pm
Marjan M,
I am Roger Davidson, not Roger Drego.
Regards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ROGER D Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2017 at 6:11pm
Genome,
No size restrictions.
Regards.
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2017 at 6:40pm
how long have you been in the business? If you really do events on that scale, it's a little bit weird that you would need to come to this forum to ask for ideas. Don't you have any personal contacts in the business? Competent employees? Why not hire a competent consultant, if you don't know yourself what to do?
If you were a real, viable business, you wouldn't waste your time here  Ouch
