  New Posts New Posts RSS Feed - 1850 or 186 Horn?
1850 or 186 Horn?
Bambotscha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bambotscha Quote  Post ReplyReply Direct Link To This Post Topic: 1850 or 186 Horn?
    Posted: 16 January 2017 at 1:20am
Hi fellow scientists
I'm planning to build a new Dub Soundsystem and i'm not quite sure wether to go for the 1850 or the 186 Horn. what exactly are the diffeneces in Sound and how do they work in various settings (small indoor, outdoor)?
Sidequestion: in a 4 way system, is a stacking of 2-4 1850s/186s really suitable as SUB speakers or should i use them as kickers (90-150hz)?
thx for your help
Edited by Bambotscha - 16 January 2017 at 1:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2017 at 10:58am
Dub Soundsystem?
imho tbh i wount be building iether the 186/1850 horn at all
dont drop anywere near for seruois lows on Roots Sounds
cookie-dj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cookie-dj Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2017 at 8:51pm
I agree, they aren't a sub cab and they aren't a kick cab either. They are a general bass cab.
Better off with a group of high power 218 reflex box really.
If you was set on going for something horn loaded for bass then maybe you could build some WSX copies loaded with V18. They sing in a group of 4
You can't polish a turd!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2017 at 1:39pm
Agreed with Cookie,
or scoops...
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2017 at 2:36pm
agreed, good for 40 ish to 130 ish hz in a block which suits some uses fine [hence why i use them]
If you want people to feel the bass then a reflex design is probably best as you get the most air movement per decibel from those.      errrrr yes wtf?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bambotscha Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2017 at 11:20am
i seem to agree on that. well but what is the 218 reflex box? is a reflex design really capable of big outdoor sessions?
WSX look crazy and seem to be the way better option! what V18 are you talking about? how is it better than the RCF 18LP300 driver?
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2017 at 12:43pm
As a sweeping generalisation, reflex can allow you to go lower in frequency for a given box size than horn loaded, but will be less efficient, so you're likely to need more boxes to get the same total volume. If you're willing to build/carry/power the right number of boxes then yes, sure they can do big outdoor events.
It has parameters that make it better suited to horn loading than the L18P300 and can handle more power and allow you to push it harder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bambotscha Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2017 at 10:39am
thx :) i think i will go for 4 Reflex Subs (because i already got them) and 2x186 as Kickers for the beginning :) should do it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2017 at 3:06pm
the 186 horn is not much of a kick cab!!! i cross out at about 120hz but i want to go lower like 100hz, some dual 15 or 12 reflex or a short bandpass horn will do the kick range alot better than the 186 horn will
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2017 at 8:36am
You don't need the kick cabs with the 2x18's. Don't wast your money, build more 2x18
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2017 at 9:02am
It all depends on music genre.
For a real Dub/Reggae Sound, the Low mid is almost as  important as the sub section.
This means 80-400hz section, must be pronounced and clear.
Most 2x18 reflex cabs are "foggy" above 150hz, and need specific drivers, with lighter cones, to achieve anything decent at this freq or higher.
Typical 2x15" reflex, handle this perfectly, though lacking efficiency. But often the SPL compromise, is worth the added detail.
Edited by levyte357- - 14 February 2017 at 9:05am
Forum Software by Web Wiz Forums® version 11.07
Copyright ©2001-2016 Web Wiz Ltd.
This page was generated in 0.059 seconds.
