  New Posts New Posts RSS Feed - 1850 re-cone kit?
1850 re-cone kit?
vmh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vmh Quote  Post ReplyReply Direct Link To This Post Topic: 1850 re-cone kit?
    Posted: 15 May 2016 at 11:19pm
Hi.
I have four 1850s i need to re-cone, three mk1s and one mk2.
The only difference i can see with the cones is that the mk2 has a dimpled dust dome.
Obviously i want to fit the same cones to all of them so I assume i can use ether?
What is the difference between the mk1 and mk2?
It's not how big it is, it's what you do with it!
32true View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 32true Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2016 at 3:10pm
up
paulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulus Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2016 at 3:58pm
smaller dust cap on mark 1 and lower power handling,the mk2 kit(silver mag) will fit into the black ones so you will have all 4 matching , i have 2 of each and all were reconed together with matching kits with out a problem , Big smile
Edited by paulus - 05 December 2016 at 3:58pm
TRENDSETTER SOUND SYSTEM
vmh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vmh Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2016 at 8:42pm
Thanks.
I have still not got around to doing them but will do soon.
This page was generated in 0.598 seconds.
