  New Posts New Posts RSS Feed - 1850 Vs. Martin Audio WSX
justamadman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote justamadman Quote  Post ReplyReply Direct Link To This Post Topic: 1850 Vs. Martin Audio WSX
    Posted: 26 March 2008 at 2:50pm
both void loaded, outdoors, lots of people, dnb and breaks, opinions please
in front of the bass bins baby
Jake_Fielder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2008 at 3:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote justamadman Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2008 at 3:26pm
safe jake
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2008 at 3:30pm
I havent read it recently so it might not answer your question properly, but hopefully it will help a bit....
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2008 at 8:40pm
on paper,for dnb and breaks,id prefer the wsx. Need the 40hz F3.
Never heard an 1850 down here though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2008 at 9:32pm
+ 1 on WSX
Michaeltandy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michaeltandy Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2008 at 9:39pm
New to the forum but will be posting a lot more and also building my own boxes, subs and tops, plan to follow soon,  but work with 4x martin audio wsx subs and 4x martin w8c mid/hi, and had the choice of that a nexo and void system and went with the martin, the tops are beautiful and sweet and the subs are just lovely on the chest.
m.j.tandy
everdark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everdark Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2008 at 6:57am
i've tested wsx with 1850 drivers a month ago. no miracles. sounded awfull. hard to carry
music is the only language I really know
CHAMPION View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2008 at 8:20am
WSX all the way
Sticks n Stones
Static Age View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Static Age Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2008 at 12:56pm
but from a DIY point of view the 1850 horn is alot easier build.
has anyone built or have any thoughts on this
Link courtesy of Tekasis
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2008 at 1:36pm
They are different horns so it depends what characteristics you want.
The 1850 horn will have a harder sound, possibly slightly louder but limited in it's low end frequency response.
The WSX is more of an all-rounder with a longer horn path and therefore more low extension.
For hard dance music the 1850 is probably what you want but the WSX will sound good with a wider range of music and definitely cope with DnB better than the 1850.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michaeltandy Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2008 at 2:35pm
I've been messing around a lot this weekend at the works unit, We have a a couple of dual 18" subs with the speakers facing each other inside the cab in a V, Although we are talking about the 1850's and WSX sub, if you want sheer battering ram of low end stick a couple of 1000 watt rms  18' subs together and see what happens, when i get the chance i will plan them up on spec sheet, see what you guys think.
m.j.tandy
