2/18 port ? |
Post Reply | Page 12> |
sn95
Registered User Joined: 10 March 2013 Location: USA Status: Offline Points: 351 |
Posted: 12 September 2014 at 1:55pm |
Is three 4in port,s enough for a dual 18 box to prevent port noise ?'boxing question is 14.5 cuft .
patryk1305
Registered User Joined: 13 December 2012 Location: United Kingdom Status: Offline Points: 488 |
You can always sim it in hornresp and find out :)
sn95
i have winisd but my labtap is not working so i can't sim .
No one will be able to answer such a question. You will need to simulate the cabinet, tuning frequency with, the TS Parameters of the driver to get the answer.
Best Regards, |
patryk1305
PM ME all the info and I will sim it for you in hornresp if you want :)
sn95
First thank you all for your help . After working on my laptop I got winisd to work .my port velocity is 1.986 m/s peak at 30hz is this low enough ?
patryk1305
Seems VERY low, 10% of speed of sound is acceptable for PA I would say (34m/s).
sn95
Thank you .it looks low to me to looking over my input,s
The Builder
Old Croc Joined: 03 January 2010 Status: Offline Points: 3107 |
Now that's a useful bit of info |
It just is.
DMorison
Far too low to be right, actually. My 1st guess, you haven't input the actual power you'll be using them at yet, perhaps? (That looks awfully like the 1W figure, not the 2 or 3 thousand Watts you might actually want to run them at.) Have a look at the G-Sub on this site - its port is roughly the equivalent of 7, 4" diameter ports. HTH, David.
patryk1305
I simmed it for him already, and the port velocity exceeded 107m/s at full power. I also suggested for him to look at the G-sub :)
sn95
Thank,s guys for your help .winisd is sim it at 1 w not at full power that is why it's showing such a low reading .as for the Gsub this is my take on it ,I have changed some of the measurements to better suit the driver I have .later today I will go back to my sim in winisd and reset to get reading at full power and change from round ports to slot .
