2 in 8 out |
Post Reply | Page 12> |
GAZ.
Old Croc Joined: 16 January 2007 Location: Hertfordshire Status: Offline Points: 2433 |
Posted: 28 November 2016 at 9:13pm |
My BSS omnidrive 388 is playing up again. I'm sending it in to dba to be looked at this week but it might end up being uneconomic to repair. Any recommendations for a replacement should this be the case?
100% Earth Moving Bass
brokenjoe
Old Croc Joined: 31 May 2009 Location: Birmingham Status: Offline Points: 3722 |
budget?
error 404
cravings
do you want another? i have a turbo lms700 that i blanked all the turbo presets off.. so it's just a blank 388 now.
GAZ.
Maybe, does it work 100%?
cravings
as far as i know, yes. it was in an install before i got it.. i've never really had any cause to use it so it's been on the shelf. dug it out to clean it up to sell a while ago, figured i'd factory reset it to remove the user presets, but didn't realise that would clear all the turbo ones too. oops.
what went wrong with yours? |
GAZ.
It's latest problem is that you have to switch it on and off a couple of times before all the outputs work. The other problem it did have, and went in for repair once before maybe a year or so ago, was display flickering and all output meter LEDs hitting the top and popping and banging through the outputs. The problem was in the power supply and was sorted out. However it did that again Saturday when I used it. I thumped the top of the rack and it settled down and worked perfectly for the rest of the night. George at dba suggested it might have an issue with the dsp board, if it is it's pretty much game over.
cravings
ouch. they're proper problems alright.
GAZ.
I'd normally fix any problems myself, but this Is a bit beyond what I can do. . I've a feeling it will be bad news hence my seeing what else is out there at the moment. I do like the 388 and I'd have another one but I'd need to be sure it would be 100% reliable.
cravings
yeah. they're such a critical bit of kit. i'm not aware of anything wrong with the one i have, but it is 20 years old. my phone camera is rubbish but here are some photos of it.
anyway, sure see what comes back on yours, and what others say here. the lead suggestion these days will probably be the dbmark 8 out ones. or andy blue aran just posted one on his ebay (in for sale section here). |
aziz
Registered User Joined: 12 January 2011 Location: ireland Status: Online Points: 136 |
Hi Steve
Well in the 14 years that I had that lms, I never had a problem with it but as you said its getting a little long in the tooth now |
levyte357-
I've had Bss 388 and Turbosound LMS700.
Now upgraded to DBMark DP4/8 MKIV. Walks all over my old '388s in terms of sound quality, versatility. No more d*cking around trying to find lead and s/w to link to laptop, and ability to play 5x way stereo (summed kick and sub), is priceless. |
toastyghost
Get the Linea SC48 if you want a proper good DSP. Or the NST Audio / FFA unit.
