2" tractrix horn, any interest? |
Post Reply | Page <1234 14> |
SouthwestCNC
70,s hero
Young Croc Joined: 14 December 2014 Location: bristol Status: Offline Points: 637 |
Just interested why 300HZ, I may be interested in a couple of these
Top banana
SouthwestCNC
The concept for me was to go over FLH mid bass that cover 90-370hz without the need for a separate mid high horn. With a coaxial, will appear as a 3 way system opposed to 4 and wont have masses of unneeded overlapped responses. Edited by SouthwestCNC - 28 February 2017 at 6:48pm |
Using unconventional methods to attain a general idea on what a concept can become is the art of a creative mind.
Usually one 300 Hz horn per column should get the job done. It is nice to see someone focusing on midrange for once than the never ending threads on bass and treble.
Best Regards, |
70,s hero
Interesting.. what driver do you think would be best or the horn, TBH, I dont really understand, is the horn covering 90-370HZ then?
Top banana
A 300 Hz horn covers 300 Hz - 20 kHz Best Regards, |
70,s hero
Thanks, yes, that is what I thought
Top banana
SouthwestCNC
bms 4590 or 4592 coaxial
SouthwestCNC
Needs to be done with the aim Good vocal reproduction in the mids with FLH'S instead of bph With james secker and teunos help, thanks guys. Edited by SouthwestCNC - 28 February 2017 at 8:13pm |
ceharden
On the subject of the mouth termination, I hadn't zoomed in on the image so it wasn't clear that there was a radius there. Obviously the bigger the radius the better but I guess that conflicts with my other point about the size so there has to be a compromise somewhere.
If they were just a touch smaller then I'd be very tempted to get some to play with the B&C DCX50 but I'm very keen on trying to keep my cabs within the standard truck pack width.
bitSmasher
Old Croc Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2295 |
Is the DCX50 still available? I'm hoping to find a pair to try in a different big horn (EV HP640)
tv00
Old Croc Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
Love that, quite interesting, yet I still have a weak spot for low compression phaseplugged mids, but I love straight kicks! Yet the illustration makes my nose wrinkle, why all this good work for a comb filter wall? Another idea popped into my head: It would be amazing with some comparable real world measurements to compare different sub designs like hog, th18, CBe, Keystone, scoops, flh. I know some has been done with scoop (danger word:-) A big row of hogs & ths always makes me wonder if you wouldn't be better of with FLH due to the low-end coupling? Of course this depends on the use, if it's sometimes just 1 / 2 subs ths are probably better. |
