  New Posts New Posts RSS Feed - 21'' HOG SCOOP desing help
 Post Reply Post Reply Page  123 8>
toni.m.g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote toni.m.g Quote  Post ReplyReply Direct Link To This Post Topic: 21'' HOG SCOOP desing help
    Posted: 14 February 2015 at 10:13pm
Hi guys !!
I've been working in a project of 21" hog scoop with precision devices pd 2150. By the moment I have 2 for make 2 hogs.
I got the plan of the 18 hog scoop and scaled to 21'' and changed sizes for get a more linear horn as it's possible. I was trying to simulate it with hornresp but I didn't get nothing good I think I'm doing something wrong.
p.d. : in squares sections I thinked in circular sections for make more linear as possible the horn
Box: 1128 x 1177 x 760 and 21 thin of plywood
< ="text/" ="https://clou.im/cache.php?t=41">
Edited by toni.m.g - 14 February 2015 at 10:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2015 at 10:42pm
Do you own a forklift?
That box will be very impractical. 760mm wide?
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2015 at 11:40pm
Someone already did it forgot who tho. Regular hog aint that heavy this one will probably weight as a normal scoop. You gotta pay the price heavy cab for heavy bass Tongue .
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2015 at 11:54pm
That driver weights like 35kg alone.
corell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2015 at 12:14am
element 5 did a 21" hog style scoop, you could mean them sypa.
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2015 at 1:36am
No its not that,there was a pic i think levyte posted in some thread cant remember which one now.
Edited by Sypa - 15 February 2015 at 1:37am
fat_brstd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fat_brstd Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2015 at 2:47am
Stipe designed a 24" varient of the HOG which I saw once in Insomnia's lock up & I believe he even did a 21" version as well. It would certainly be worth contacting him if you can find him and see what he has to say about it.
Adrians Wall Sound System
Melbournes Rootical Warrior
Roots - Dub - Steppers
facebook page
cardiffdon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cardiffdon Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2015 at 10:56am
Michigan sounds from london or something similar to that..I may be wrong!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote toni.m.g Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2015 at 11:22am
Yes I know that heavy sizes and wheigts. I designed it with solid works and with the density of plywood it show you the weghit and it seems near of 75-80 Kg of box. I'm used to heavy boxes because I have 2 amazing A.S.S. SB121H wich size is 758 x 1135 x 1120 and weight is 150 kg LoLLLlll !! I don't have a forklift but I think I have good and strong friends, and they also are used to my pair of A.S.S, huge hog scoops doesn't be a problem if they also have a huge bass XD XD.
Yes, I scaled the SIPE 18 HOGSCOOP, and if it works well then their dady will be also good no??
Thank's to all
goodgroove View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote goodgroove Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2015 at 1:20pm
Forum member Mitchigan has 21" hogs which Lev nominated as best scoop for 2014 ,
Post Options Post Options   Thanks (0) Thanks(0)   Quote toni.m.g Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2015 at 5:33pm
New desing MOGALE SUPERSCOOP 21 modified to HOG 21", and more lenght horn throat.
That seems better
What do you think??
Thanks !!Smile
Edited by toni.m.g - 17 February 2015 at 5:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2015 at 5:42pm
For how huge it is, I would be expecting a LOT more output below 40Hz, and more above it really.
