24" drivers |
Post Reply | Page <1234> |
MPASOUND
Registered User Joined: 25 April 2006 Location: UK Status: Offline Points: 258 |
Sorry Elliot, I am well aware that headphones are loudspeakers, I prefer to feel my bass though!
It's just bits of paper flapping about in a box.
gen0me
Forgot to say with 15mm Xmax suspension you got left 5^2 cm of Sd left
Now consider your distortions. |
MPASOUND
That all depends on who's 18's you are comparing too. Also I quoted sd and didn't mention x-max. This is a HiFi, I don't need 15mm of x-max. Each driver barely moves at normal listening levels.
I am a strong advocate on low bass hence, owning lots of double twenty-ones, double eighteens that have no issues delivering 20 Hertz. For those who cannot achieve 20 Hertz with their speakers, headphones are the next best option instead of settling for anything less. Best Regards, |
70,s hero
Young Croc Joined: 14 December 2014 Location: bristol Status: Offline Points: 637 |
Consider that, most 18" drivers are not very linear at all due to the high xmax required.A larger driver can stay at small excursion however the requirement is for it to produce sound pressure levels at the optimum amount which takes it out of any linear characteristics that it may have. The same sound pressure levels can be achieved with smaller multiple drivers but with a more linear result due to the ability of the voice coil to remain at its optimum efficiency (within the field). Think of this..the motor is essentially two magnetic fields one fixed and one created by the VC.the point at which non linear characteristics are introduced is when (given a single frequency) of say 30HZ is when the VC starts to leave the most intense part of the fixed magnetic field. This is a characteristic of most high powered 18 drivers where normal excursion produces variations in EMF within the motor that contribute to the non linear response or distortion. The cone flexing and power compression are also issues that smaller drivers suffer from less. Edited by 70,s hero - 23 February 2017 at 10:20am |
Top banana
MattStolton
The only real issue of multiple drivers Vs a single, would be when the wave length being reproduced gets to be of the order of magnitude of the dimension of the baffle in which the drivers are in.
So the left most driver(s) would start to interact with the output of the right most driver(s), off axis, with a path length difference, leading to comb filtering type artefacts. However, on a "big" driver, the wave emanating from extreme left Vs extreme right, of axis, will also have a path length difference. IIRC the late Windmill Tilter did a mid box with a 4 highx2 wide array of 8" drivers, on a V baffle, and got a significant dip at 800Hz, speculated to be from just such a path length issue. However, for a bass bin crossed at 120Hz, not an issue? At low enough frequencies where wavelength is much greater than driver spacing, no great issue, but as wavelength becomes of the order of magnitude of driver spacing, you will get an effect. Same as having a long (wide) array of bass bins for directionality reasons. If it is out of band, no worries, but with reflex, you can always run a bit higher....
70,s hero
Edited by 70,s hero - 23 February 2017 at 11:09am |
Top banana
nickyburnell
Understand all of that, but compare the personality of the following 8v Vauxhall to 16v 8v Golf to 16v 12v Vauxhall 6 pot to 24v 12v Merc 6 pot to 24v Every one of those has 8v more usable drivability without revs. They have a personality rather than a benign nature and in my experience use a damn sight less fuel. Yep, in a scream it race they are slower. Modern 4v engines have become a method of propulsion lead by emissions and fuel economy (lies included). An old Fiat 1100 has a fizzy smile on face nature ( as did your Alfa, but thats an old 16v that wasn't trying to appease Erop AND you have messed with it), a modern 1100 is up 50% on power but benign. Drive any little hire car today, they are just flat. I get the yank thing with the RON, but a V8 on low quality fuel is better than no V8. BTW. I actually said manufactures would like to have 2v engines. I stand by this, they would, less parts is good for profit, but they no longer can due to restrictions V8 = SMILE 24" = SMILE Edited by nickyburnell - 23 February 2017 at 3:32pm |
Crashpc
Registered User Joined: 26 February 2008 Location: Czech Republic Status: Offline Points: 465 |
That looks very irrelevant to me. We´re looking at particular outcome. I.E. Linearity, excursion, displacement. Not at the datasheet data. There is no hard set higher requirement for 21" or 18" to have larger Xmax than what 12" drivers have. But while it HAS, it will work in more linear fashion under Xmas, while 12" driver would have to be AT its Xmax for the same output. I.E.: 21DS115 has 36mm long voice coil and 14mm top plate. That is pure mathematical 11mm of old-school Xmax, where the coil doesn´t leave the gap. I note, that it is deep and thick gap, to use it later. Then there is 12NW100 and 12TBX100 in the B&C line, which has 25mm long voice coil and 12mm thick pole pieces. That is 6,5mm of mathematical Xmax. For the 21DS115, that excursion is significantly under its Xmax. I would not hesitate to say fully 2x. In that excursion, the 21DS115 will work in more linear fashion than group of 12"s. Also, the thicker the pole piece, the less distortion you have at, or past this Xmax, beccause less % of the gap is unused when you go lets say 2mm past Xmax. For example for 4mm pole piece, it is half of its thickness. Serious distortion. For 14mm pole piece, it is under 15%. So for the linearity and displacement, larger speakers with larger possible excursions usually have the edge. The idea of more voice coils is cool, but it doesn´t deliver yet. Only if you have serious money, and you put more drivers in the box, so the sd area is larger. Then it is superior. |
70,s hero
In isolation looking at the 21DS115, B C go in to some detail within thier explanation of the design parameters with reduced excursion providing less distortion which happens to be what I have been advocating, I see that they quote xmech in place of xmax which is sometimes confusing. xmax is the distance that the vc can travel before it starts to leave the magnetic gap. Regardless of this the fundamentals remain where larger drivers have higher amounts of distortion over smaller ones due to various mechanical and electrical properties.
Top banana
MPASOUND
A little off topic but does any manufacturer spec xmax correctly other than BMS?? Everyone else seems to add a varying degree of 'fudge' factor..
Crashpc
They don´t quote Xmech in the place of Xmax.
Xmax is not that parameter anymore due to the obvious reasons I explained. It leaves out magnetic assembly qualities, and mechanical assembly qualities as well. Two speakers with the same "your Xmax" can yield VERY different results. That way, mathematical formula you use is not valid for as, as it doesn´t describe real distortion anymore. It haven´t from the beginning.... |
