2x10" vented horn idea |
Post Reply | Page <1 6789> |
JonB67
Been looking at the design, really doesn't have much volume behind the drivers and wondering how much this effects its output.
What frequency will you cross it to subs? |
MarjanM
Very good work. I ma working on similar 2x12 box.
However, this box does not really classify as a vented horn. Its a reflex box. :) |
JonB67
Ive been looking at drivers for a 2x12 version this morning!
BP1Fanatic
Registered User Joined: 02 August 2009 Location: Columbus, Ohio Status: Offline Points: 105 |
These speakers came out nice as h3ll!
DJGeno
New Member Joined: 24 March 2018 Status: Offline Points: 8 |
Can anyone comment on how the horn flare interacts with the port? Surely it will have a negative effect on it with it being so close, and with the horn throat passing through it? Will this reduce the performance of the port? I'm a complete newbie and trying to understand the physics of it all.
Noud
Registered User Joined: 17 August 2014 Location: holland Status: Offline Points: 66 |
Goodevening Guys,
I Started building some new subwoofers to replace my scoops. so I looked at a lot of different kind of subs like: -th18 xoc1 -cyclops -tham18 -tham 15 -Cubo sub -21 br and finally a paraflex Altcon 15 I wanted to be smaller go just as low or lower en just as loud. (if possible) so I started reading and reading and a bit more of reading. until I finally decided to go with the Paraflex Alton 15. the Hornresp sim so a similar output and range as the scoop. so I de build begon and there are some result in the pictures. Keep in mind the scoop is about 590Liters and the Alton 15 only 312Liters Green=scoop 18XB Purple=Altcon 15ds115 HPF=34hz LPF=100hz
Noud
edit
Edited by Noud - 02 July 2020 at 9:05pm |
Tonskulus
Registered User Joined: 15 September 2017 Location: Finland Status: Offline Points: 425 |
Interesting! How about ground plane measurements? Measure at least 4meters away.
Noud
I did it at 2m low volume and it’s about the same. ( don’t have a lot of space to test)
When there is a bigger space available I will measure it from some different distances
JonB67
Measurements aside, how does it sound to you subjectively?
Interested in feed back on the paraflex vs horns, tapped horns and reflex.
Noud
It sounds tide, clean, kick nice, makes the scoops sound "slow".
I havent got the change to compare them with anything als but scoops. maybe in the future I will get the change. a friend of my got 18xb reflex. For a good testing day I first need to find a space to test. |
Tonskulus
Poor ancient scoops.. tapped horns and paraflex systems are todays stuff.
