  New Posts New Posts RSS Feed - 2x12 PPSL anyone?
2x12 PPSL anyone?
pfly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pfly Quote  Post ReplyReply Direct Link To This Post Topic: 2x12 PPSL anyone?
    Posted: 12 August 2011 at 5:53pm
Some time ago I sketched slot loaded push & pull design for two BMS 12S330/12N630. Around 70-75 litres tuned to 38hz, at least should be. Slot is just big enough to load those drivers with some 9mm between them when loading. Structure is pretty much self bracing with driver baffles and ports, extra bracing should not create two different chambers. Feel free to try if you're brave enough. Excursion hits 10mm with 1000 watts at 50hz
predicted 2pi / 2v / 4ohm without slight gain/filter in upper bass that slot may cause
http://dl.dropbox.com/u/9726318/212pp/212pp.skp
Edited by pfly - 12 August 2011 at 5:58pm
VentureSound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VentureSound Quote  Post ReplyReply Direct Link To This Post Posted: 12 August 2011 at 9:05pm
What's the calculated f3? Looks about 38Hz from the graph?
loonie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote loonie Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2011 at 5:46am
Am I right in saying these are the "extended/doubled" 12" Hybrid Horn plans?
If so, you've made me a very happy man indeed.
Many thanks Pfly!
Edited by loonie - 01 September 2011 at 5:47am
Team DB
pfly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pfly Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2011 at 8:23am
They are not. Sorry, totally different thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2011 at 4:58pm
Need more details.
Post Options Post Options   Thanks (0) Thanks(0)   Quote loonie Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2011 at 5:02pm
*Continues to wait patiently Smile
Team DB
pfly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pfly Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2011 at 5:29pm
Sketchup is free software, anyone who wants to try out this design can download it and measure plans from the .skp
I am not sure if I ever release 2x12" hybrid design. I have moved on from there.
Concept seems to be working nicely. I am working on 2x15" version that shares many aspects with Martin 215 mk3 and F2B, on pure coincidence looks pretty much like Martin MLX and is almost exactly the same size as Arcline X. I tell you, without space age materials of Arcline X it is amazingly tight fit to cram horns, ported chambers and 2x15" drivers into that space.
pfly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pfly Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2011 at 5:33pm
Another thing: would anyone be interested in Psycho bin sized Front Loaded Horn meant for usual suspects, PD.1850 and V18-1000 with 230cm horn path and Martinesque letterbox -throat?
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2011 at 10:16pm
"Continues to wait patiently"
If you liked the performance graph for the posted design, why not build the design?
It will go lower than a similar sized horn, and have less distortion.
djk
Wrek0ne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wrek0ne Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2011 at 12:05am
Do tell more ... Big smile
Poll this!
pfly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pfly Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2011 at 12:56am
Here it goes...
PD.1850 0,5pi / 1,41v and 2pi / 2,83v
Dimensions are 122x84x63,6cm
Nice smooth folding and expansion. Models around the same as Nineleave's Invader but in reality it has more horn length and to my eyes perhaps nicer expansion. Different character it will definitely have. I am also sucker for Martin's letterbox throat because it creates definitive throat such as compression drivers and mid horns have and it almost minimizes the size of compression chamber, it really makes horn act as a horn in most classic way.
Problem is it either need side access panels like LAB and Punisher or then something like I drew in that model and what Mykey did in one of his designs.
hmaudio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hmaudio Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2012 at 1:59pm
[QUOTE=pfly]Here it goes...
[/QUOTE/
more info on this please it looks very promising! did you ever take this any thurveR?
cheers
Adam
