2x15" Gsub |
THECANDLEMAN
Joined: 08 December 2008 Location: CentralScotland Status: Offline Points: 687 |
Topic: 2x15" GsubPosted: 26 September 2009 at 10:41pm |
hey guys have read through a lot of this section and other projects etc ! I want to start my first project and I have two 15" drivers I took out a pair of scoops. want to build a 2x15" Gsub as long term I want to build two 2x18" for live music work The questions I am asking is 1. does anyone have dimensions for a 2x15" Gsub (will this change a lot depending on the drivers I have?) 2. has anyone build one before and have any advice/pictures etc Oh and I have someone who is going to do all the cutting etc for me as a favor when I get him some plans ! thanks TheCandleman |
mikey bear
Joined: 29 October 2007 Status: Offline Points: 2377 |
Posted: 26 September 2009 at 10:43pm |
you could try the b&c 215. http://www.bcspeakers.com/suggested.php?id=0000000009
what drivers do you have? |
ceharden
Joined: 05 June 2005 Location: Southampton Status: Offline Points: 9222 |
Posted: 26 September 2009 at 11:36pm |
The best thing for you to do is learn how to do simulations using WinISD (or similar). Stick the parameters for your drivers in and find a combination of volume and tuning that will work. This will partly depend on what compromises you want to make.
In general, if you want to go lower, you need a larger box. You can go low with a smaller box but you loose efficiency. I find that generally you're better of sacrificing a few Hz of low extension and benefiting from higher efficiency, often a smaller box and if you're lucky a tighter, punchier sound (which is often the reason for wanting twin 15" rather than 18"). Most 15" drivers suitable for reflex loading will be happy in a box around 100L per driver and tuned to 40-45Hz. Once you've got a simulation you're happy with you can then transfer that to a cabinet design. If you like the GSub style, stick with that. First set some constraints, the size of the baffle is generally a good place to start. From that you can calculate how deep the box needs to be in order to get the volume. Don't forget to include the port volume! You design the port in WinISD. |
THECANDLEMAN
Posted: 27 September 2009 at 9:41am |
Thanks
I found a design I like on sonotone.in http://www.sonotone.in/images/PDF%20File/cabinet_drawings/Dual%2015%20inch%20Subwoofer%20C15-600EL%20x%202.pdf gonna have a look at WinISD and play around with measurements thanks for the advice THECANDLEMAN Edited by THECANDLEMAN - 27 September 2009 at 9:42am |
THECANDLEMAN
Posted: 27 September 2009 at 1:10pm |
OK, here is my other problem
got my drivers our of a pair of scoops I acquired. but they don't have any marking on them. can anyone tell me what they are...............? ![]() Edited by THECANDLEMAN - 27 September 2009 at 1:10pm |
Tekasis
Posted: 27 September 2009 at 1:16pm |
Like the look of this plan! Anyone on here built it before?
**Heavy Weight-Line**
A home without books is like a body with no soul. |
THECANDLEMAN
Posted: 27 September 2009 at 2:36pm |
been looking around for a bit, only found 2x12" and 2x18" in similar styles
would love if anyone does have pics of this build to share them etc |
silworm
Joined: 28 September 2004 Location: Portugal Status: Offline Points: 266 |
Posted: 29 September 2009 at 4:31pm |
I've been searching for something like this the only thing is this one uses 19mm ply so you have to take that in consideration...
Tweet
