3 phase not needed |
Post Reply | Page 12> |
mykey-
Old Croc Joined: 03 March 2010 Location: ID/UK Status: Offline Points: 6114 |
Posted: 14 April 2011 at 7:16am |
Hi Guys!
As you know me and Tony (ASS) have spoken about 'GOOSENECK ROUTERS' aka 'PIN ROUTERS'.The machines on the market today are 3 phase (let me know different) and are very bulky and have small beds. You can't buy these here in Indonesia, you can have them imported but cost a fortune, and you can't import second hand machines into the country. And add the fact that they may break down is a pain. What I decided to do (as usual) was build my own with a good engineered heavy duty 240 volt router, if it ever breaks down it takes minutes to replace with a second spare I have. For those that have never heard of these machines, basically it's a copy router, what ever pattern you have on your jig, it will replicate above. Both me and Tony have stated that we can actually work quicker with a pin router than what people can do with a cnc. I also made it with a 6ft wide by 4ft deep bed something my old machines never had. To raise and fall the pin I have used a large nut and bolt bored out by 12mm to house the pin, then welded a bike crank with bearing handle for ease of use. The rise and fall of the actually router housing is done via pulleys and a foot pedal and plastic shield coated steel wire bond. This machine is very accurate, easy to move around if needed (no crane), and can accommodate large jigs. The machine took me 2 days to build with the equivalent cost of 300 pounds sterling. Add the fact that a 240 volt 'HOBBY' router doesn't make that much noise you could build one for your shed send me a years supply of pork pies and piccallili and i give you the plans don't bother trying to send chow mien because you won't get an asnwer I'll upload the pic's taken with my handphone BTW, I can weld, which helps. But most people can with 10 minutes of training this would suit someone like members Saul or Builder Edited by mykey- - 14 April 2011 at 7:51am |
mykey-
mykey-
and another pic of the vertical DIY panel saw
have you notice that the Japanese have designed the Hitachi router to look like a robot : ) and some images of pin routers here http://www.google.co.id/search?q=pin+router&hl=en&client=firefox-a&hs=bqb&rls=org.mozilla:en-US:official&prmd=ivns&tbm=isch&tbo=u&source=univ&sa=X&ei=EZimTaGvMoLWvQPE0dWXCg&ved=0CC8QsAQ&biw=1366&bih=486 Edited by mykey- - 14 April 2011 at 7:49am |
tweeter box
Old Croc Joined: 21 October 2007 Location: United Kingdom Status: Offline Points: 6784 |
top stuff Myk
tomschute
Old Croc Joined: 15 May 2006 Location: Mid Wales Status: Offline Points: 1817 |
wow you literally have child labour
edit: great looking machine by the way! I was thinking about these just the other day - weird. Edited by tomschute - 14 April 2011 at 9:22am |
www.stableaudio.co.uk Speaker Building Services |
bitzo
Registered User Joined: 20 November 2007 Location: Italy Status: Offline Points: 977 |
What it the purpose of the myckey mouse ears on top of panel saw?
SBC
Registered User Joined: 25 November 2010 Status: Offline Points: 1266 |
another "homemade" tool we have made at the workshop is a spindle moulder with a nice wide bed. |
F.T.S.S.
tomschute
I made a vacuum former a couple of years back - that was cool.
cravings
wow, cool.
mykey-
yes saul, Spindle molder maybe next on the list, But at the speeds they run at I'll have to take double care. Got any pictures?
@Tom, we work 99% of the time with our shirts off because of the heat. Actualy he's married and 27 mickey mouse ears are pulleys |
mykey-
mykey-
