3 tops a side - 4 and 8 ohm load |
Sirbrins
Registered User Joined: 25 February 2010 Status: Offline Points: 74 |
Posted: 26 September 2014 at 5:43pm |
Hi,
If I run 3 tops on one amp, 4 ohm load on one channel and 8 ohm on the other, will there be a noticeable difference in volume or sound quality between the different loads? The power difference is only 50 - 100w. Cheers, Sirbrins Edit - poorly written! Edited by Sirbrins - 26 September 2014 at 7:47pm |
adyk
Registered User Joined: 05 May 2009 Status: Offline Points: 442 |
correct me if I'm wrong but how do you get 3x 2 way speaker a side to run 4 ohms or even 8. what ohms are the speakers to start with?
mini-mad
He means 3 cabs run off one 2x channel amp. One speaker off channel A and 2 speakers off channel B.
adyk
Oh, ok that makes more sense.
rish
Young Croc Joined: 18 June 2008 Location: Durban Status: Offline Points: 547 |
You would not have a problem and shouldn't notice much difference.
Old Croc Joined: 02 April 2004 Location: United States Status: Offline Points: 5172 |
Nevermind.
Best Regards, Edited by Elliot Thompson - 26 September 2014 at 9:22pm |
Conanski
