3 way horn loaded mid top |
Post Reply | Page <1 345 |
nickyburnell
There is a two way solution. D&B C7.
There are plans out there with suggested drivers and DSP settings. Commercial cab so no posts, but have seen one these (originals) cover a stack of 3 Turbomax USB's on the correct amp, a mere 600w or so of passive cab per side for 12 x 18's. I was stunned and started looking for the hidden cabs. TimB and Barry P can confirm this. |
midas
Old Croc Joined: 27 October 2011 Location: Cumbria Status: Offline Points: 2117 |
So.......These are the boxes Joe Venny is making.....
midas
What about eaw 695's? They look very mean....
toastyghost
I honestly haven't heard a full box, but I have heard the coax on that horn and that alone is on par with anything at the high end of pro kit. J2 is a personal favourite of late, I seriously want a pair. J3-94 made more sense for us right now though. Would like to hear the Lambda. I would say that point source is maybe just being spec'd where it should be more often. Of course the option to do a big show with special point source is also nice, I'm skeptical of the KV2 comp setup at serious levels though have only heard it get bitey |
MattStolton
Surely an easy route for all this, is what the Late Windmill Tilter knocked up, for Ebony Show case IIRC.
Double 15 in a reflex box, so easy to knock up, and easy to get a wide range box, to meet the BMS coaxial in a seperate box on a big horn. Ease of transport/crew requirements, could even do multiple single 15" boxes for real one man depolyment.... Most 15" drivers will do 80-500 reflex with low stress, in a relatively compact box. V baffle for more compactness, as you will cross lower than 600Hz ish, so any cancellation/beaming will be out of pass band. Simple? The HF box, could be skeletal, or thin wood to save weight, it is just housing the speakon to HF, protecting the passive 6K X-over, and supporting the Driver to the horn, so its weight doesn't snap the horn during transport. Bit of strength between baffle and driver, but other than that, waxed cardboard would suffice! I think they also had some form of angle wedge doofus for the HF box, to ease vertical aiming. You could go to town on some trick metal work; think how a projectors feet work, for level and aim, cheap but effective? Directivity of reflex 15" drivers in the band 100-500 is a bit of moot point, as the wavelength vs physical length is not quite comparable, but other than that, what is the issue? As long as the 15" is starting to beam a bit at X-over point, to the same sort of horizontal angle that the horn high mid is working at, should assist transition from mid to mid high. Would work fairly well with any number of competent 12" drivers for the 100-500Hz band. Think RCF 4pro 6001, but rather than 8"+HF, combined BMS coax on a single horn. You could even hang that in front of the 2x12"/2x15" if compactness was an issue. If height is required, keep to seperate box for coax+horn? Just my musings, carry on....
bass*en*mass
Comparing a double 15+coax to the cabs above other than the DIY is quite apples and oranges imo..
peter morris cab is compromised to highest output in smallest size, its restricted to 2 cabs per side. (double 15 might have same output and restrictions but much larger) All the others like vhd5.0, QX and J2 are bit different animals in therms of output and pattern control/arrayability. |
bob4
Old Croc Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1842 |
Mark James
If 100\110 Hz is ok then clovers design might be an option?
MrScy
Registered User Joined: 23 June 2017 Location: South Africa Status: Offline Points: 34 |
This is hard to believe. 3 x Dual 18" bandpass should need more than 1 C7 seeing that the stack from the factory is 2 x 18" per C7. The C7 is also the least powerful in the D&B C series with the C3 being the most powerful. Kind regards,
montek.co.za
