  New Posts New Posts RSS Feed - 32A TPNE PCE IP44 Outlet - No cable clamp!!!
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Topic: 32A TPNE PCE IP44 Outlet - No cable clamp!!!
    Posted: 01 August 2012 at 2:43am
Just opened up one of these I got off ebay couple of weeks ago.
http://www.ebay.co.uk/itm/415V-32A-5-PIN-SOCKET-RED-GARAGE-WORKSHOP-3-PHASE-32-/190384461275?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item2c53cc55db
415V 32A 5 PIN SOCKET RED GARAGE WORKSHOP 3 PHASE 32 A
Inside, no cable clamp to be seen !!!
Is normal for some or just means el cheapo chinese copy?
Item is the one from above.
Edited by levyte357- - 01 August 2012 at 2:46am
Linux, Firefox, Libre Office. Life goes on.
audiomik View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiomik Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2012 at 2:50am
Ray
there are a whole set of 'regulations' about cable clamping and creepage which have to be met for connectors of this type. Suggest that you contact your local Trading Standards people who deal with this.
From what you've said, all of these connectors may need to be withdrawn and/or recalled!
Mik
Rule #1: "there are no such things as problems
...........................only solutions we haven't thought of yet"
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2012 at 3:31am
Originally posted by audiomik audiomik wrote:
Ray
Mik
Seems so, been wiring 32A/16A conectors all evening, all with decent clamps & doubled screws on terminals, yet the big boy 3PH 32A has no clamps..
Shocking !!! <excuse the pun LOL>
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2012 at 7:33am
this looks like the PCE type connector - with the twist lock back shell.
If so, then this is quite normal, the main gland at the back of the back shell forms the gland and the strain relief, and no separate clamp strain relief is required.
I literally have hundreds of these type connectors in my hire stock ranging up to 63A 3 phase and have not experienced a single issue - so provided that you use the right size cable for the connector's gland, you will be fine.
Before you ask - all my connectors are sourced from reliable suppliers and are not chinese knock-offs.
www.impulseaudio.co.uk
brokenjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brokenjoe Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2012 at 7:36am
they clamp in the same way a neutrik xlr does?
from memory anyway
error 404
Liteworks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Liteworks Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2012 at 7:42am
To add, make sure you tighten up the gland properly, as Chris mentions, on these are also the mechanical strain relief, so are required to have a firm grip on the exiting cable.  They are a similar design to the Lewden/palazzoli quick wire plugs, nothing wrong with them at all.
If your at all worried, put a back shell on a length of cable and tighten the gland up and see if you can pull it off.
Cheers
-matt
Edited by Liteworks - 01 August 2012 at 7:43am
www.Lite-Works.co.uk
My Kettle is 2000w! why isn't it very loud??
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2012 at 8:33am
Those PCE connectors are probably the quickest and easiest to work with (having spent whole days just wiring 16A cables) and the chuck type strain relief is very effective indeed because it clamps the cable from all sides rather than just squashing it flat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2012 at 1:28pm
+1
Tightened up perfectly.
shagnasty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2012 at 3:13pm
If you are worried just put a Cut, un-stripped 5g6 end into the connector, screw it up and try pulling it out!!!
Cee-Norm (some of the best you can buy), Pazzoli and PCE all seem to be using Collect/gland system at the min which IMHO works well...
S
biotec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote biotec Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2012 at 3:43pm
whilst the experts are here, does anyone know of a 3 phase connector (16a+) that accepts an m20 conduit thread?
I want to terminate some flexible metal adaptaflex conduit into a 5 pin connector for a generator fitted permanently under my truck to make it easier to remove it for servicing. Currently the connector is hardwired into an IP67 junction box but it's an arse to remake the connections after I've serviced the generator.
Incidentaly, 3 pins are for live, neutral and earth, and 2 pins are for a 12vdc lift pump, so a connector with a non standard keyway would be better so that someone (not me!) doesn't get a suprise when they get 12v down L2 and L3 . MK did a commando socket with an M20 thread but they don;t seem to do it anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2012 at 3:52pm
What you are talking about doing is a bit naughty for various reasons, first the plug could end up in a 415V 3PNE feed, but a 4h as apposed to the very common 6h keyway, as you said would all but eliminate that....
Second if SELV (12V) and LV (240V) co-exist in conduit or trunking etc the SELV circuits must be insulated to LV standards, IE you sould have a barrier (Like use a bt of 2 core and a bit of 3 core flex...)
Personally I'd look at something like this :-
but if you want to do the BS4343 thing McKennes Ceeform (IP67) use a PG thread for the rear gland that can be adapted to M20 with a standard thread adapter....
S
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2012 at 3:54pm
Might be a bit overkill and expensive but if you look at Harting connectors you could design your own using their modular inserts so it'll be incompatible with anything else out there.
You can probably make lots of things mate with M20 conduit with a bit of epoxy!
web department
