4r bridged scoops and headroom driver advice? |
phildat
Joined: 29 January 2009 Location: manchester Status: Offline Points: 910 |
Topic: 4r bridged scoops and headroom driver advice?Posted: 18 February 2012 at 8:57pm |
Owing to a change in the set up of my rig, I have decided to incorporate some G subs. These will be stacked on top of just two Rhinos laid on their side - mouths coupled loaded with V18 1000s. Plan to run the Rhinos 4r bridged off a Matrix XT5000 ( not flat out!35Hz-80Hz). Is this going to be possible off a 13a socket?
G subs are going to be loaded with XBs (i think) and run off XP5000. 80 Hz-180Hz but i do worry about the XP running out of headroom. Can anyone recommend alternative less powerful 18s that i should consider for the G subs that might give me more head room? Many thanks |
Its all about my ego. He goes where i go.
phildat
Posted: 18 February 2012 at 9:43pm |
anyone?
levyte357
Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11083 |
Posted: 18 February 2012 at 9:50pm |
Not all amps can handle being bridged and run 35-80hz.
If your amp won't have the headroom to drive XBs, shouldn't you be considering more powerful amp? Never heard of someone downgrading drivers (especially XBs), so amp is happy. Usually hear about amp upgrade. |
"This thing is brutally loud. Only been flogging it in the workshop so far but it was amusing listening to the windows rattle as the wave makes it way down the length of the workshop.".
andycw
Joined: 17 November 2010 Location: Norfolk Status: Offline Points: 414 |
Posted: 18 February 2012 at 10:16pm |
Maybe he doesn't have the funds for a more powerful amp..?
There's a thread about using the Thomman 18" in the G-sub have a read of that.. Edited by andycw - 18 February 2012 at 10:16pm |
No Bass No Fun
soundchippy
Joined: 09 September 2011 Location: Northampton Status: Offline Points: 491 |
Posted: 18 February 2012 at 10:21pm |
wouldnt a gsub play lower than a pair of rhino's?
pfly
Joined: 25 October 2007 Location: Helsinki, Fin Status: Offline Points: 2165 |
Posted: 18 February 2012 at 10:30pm |
G-Subs probably play lower than two miniscoops, however, miniscoops efficiency around 40-70hz or so should be better.
I don't see point in worrying about that you don't power enough reasonably sensitive drivers. Yes, you could "downgrade" your drivers to other drivers with smaller RMS rating but it is always not obvious that they would also be automatically more sensitive, in which case you would actually gain something in process. If you are worried that your amp is not manly enough for the drivers you are using, just use it on the damn things and don't let it clip, that's all. As long as you don't clip the amp, drivers should be really happy running with lesser power than they could take. When the time is right and you feel like it, upgrade the amp. Simples. |
levyte357
Posted: 18 February 2012 at 10:32pm |
What he said. |
Tweet
