4th order isobaric bandpass sub design |
izools
Joined: 07 August 2012 Location: Devon, England Status: Offline Points: 2 |
Topic: 4th order isobaric bandpass sub designPosted: 07 August 2012 at 10:05pm |
Quick question:
I want to design a 4th order isobaric enclosure for these subs: http://www.manualslib.com/manual/282651/Infinity-1250w.html And I was using this calculator: http://www.carstereo.com/help/Articles.cfm?id=27 I want to achieve a bandpass of ~20Hz - 60Hz I'm a bit confused though the vented enclosure comes out at 0.65 Cu ft. Can that be right? Is that even big enough to house the woofer? Seems tiny to me. Just wondering whether the calculator is just rubbish? |
lost eden
Joined: 04 April 2011 Location: Fife Status: Offline Points: 514 |
Posted: 08 August 2012 at 12:12am |
This is about 0.7 cu ft (the main section, not including the port) & that's an 8" driver, should help you visualise.
Peter Jan
Joined: 16 December 2008 Location: Belgium Status: Offline Points: 448 |
Posted: 08 August 2012 at 12:16am |
It's possible to have a very small calculated cabinet. Isobaric setups do just that. They make for a very small cab compared to the same speakers in for instance a straight BR or BP setup. No free meal though... what you win in less occupied space, you need to make up with much, more power to get the same SPL. In my view, isobaric designs are most at place in home environments, where as little as possible occupied space usually is a good thing to have and SPL needs are somewhat moderate and can to a certain point be met with power (mains don't run out that easy). For pro use/on the road they don't make much sense. Even for car audio I can't see any benefit apart from the size if your SPL needs aren't too big (can draw only so many amps/watts out of a 12v battery).
_djk_
Joined: 23 November 2004 Location: United States Status: Offline Points: 4676 |
Posted: 08 August 2012 at 8:42am |
You will find that it is not possible to properly vent the very small chamber required by an iso BP4 design.
Looking at the data for the driver I suggest running a sealed box, iso if that's what you want. For PA iso is a total, utter, and complete waste of time and money. |
djk
Tweet
