  New Posts New Posts RSS Feed - 5.25" drivers
5.25" drivers
Lyndon A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lyndon A Quote  Post ReplyReply Direct Link To This Post Topic: 5.25" drivers
    Posted: 30 June 2005 at 6:55am
Whats the maximum sensitivity you can get from a 5.25" speaker?  I don't want to run an extra amplifier nor add larger speakers to the door cards.  I'd like to keep the car looking standard
At the moment the best I can find is 92-93db, I only need them to supply mid range, 150Hz upwards.
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2005 at 8:49am
If they still do them, try Fane. 'Studio 5' if my memory is still ok.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lyndon A Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2005 at 9:20am
I'm not sure if they still sell them.  They are listed on Fanes website but they don't give any tech specs.  Second hand isn't really an option as I'm going to need 4.
Tom Umney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2005 at 7:58pm
Yep Fane still do the Fane Studio 5 inch drivers which are  Fane STU.5FR [fullrange driver rated 35w AES, 50hz-15khz] and STU.5M [midrange only driver rated 50w AES,90hz-8khz].
Sencesync View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sencesync Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2005 at 3:58pm
actualy, you wont find much higher then 92-93 sensitivity on most car stereo drivers. the highest iv ever seen are on some SPL brand subwoofer for cars. like audiobauhn's 15" 4,000watt extreme extertion subwoofer, it has 99DB. i also have a 12" 2,000watt ADF929, i do believe it has a DB of 97 or 98. this is only because they are SPL compitition subwoofers though. so anything around 90-95 for in car systems is about as good as it gets, that is if you stick with car audio....>=] *cuagh caugh* its not a good idea to use pro audio drivers with 100-102db sensitivity *caugh caugh* (thats a hint by the way)
rastaman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rastaman Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2005 at 1:14am
Why?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lyndon A Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2005 at 6:46am
I found some Polk Audio (I think thats the right spelling) that at 93db which isn't too bad. I think anything would be an improvement on the standard 13 year old foam surround drivers. I haven't even looked at them, probably knackered!
LunchieTey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LunchieTey Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2005 at 9:46pm
you'll probably be disappointed to find out that cheap oem drivers are generally rather efficient! Even 93db speakers prolly will actually sound quieter(if volume is your main concern) due to lower thd and a somewhat less nasty midrange!
Also don't forget you're head is only 1.5mtrs or less from your speakers! I use 85db efficient 5.25" MB Quart splits in my car with around 40wrms each and that is PLENTY(and my car is rather loud thanks to massive exhaust,pod and oversize throttle body/induction cams etc)
Speaker addict
